Modding Rainbow LED
Discussion in 'Article Discussion' started by macroman, 27 Aug 2002.
  1. macroman
    macroman The One
    3 Sep 2001
  2. MajestiX
    MajestiX What's a Dremel?
    14 Apr 2002
    nice work macro as always....
    how bout somepics of it working or avi???
    Cheers,
    MajestiX.
  3. i_h8clowns
    i_h8clowns <img src="http://www.bit-tech.net/ataraxia/it.gif"
    9 Sep 2001
    w00t!
    thanks macroman! :D :D :D :D :D :D :D :D : D
  4. i_h8clowns
    9 Sep 2001
    this is the LED i am going to use. it has one less blue anode and common cathode than the LED you use. but there shouldnt be any difference right?
  5. macroman
    macroman The One
    3 Sep 2001
    There are differences but it should work ok. You may need to change the resistors R1-3 to match the brightness?
    Phire - why did you delete your post?
  6. Ice-T
    Ice-T What's a Dremel?
    27 Aug 2002
    Hello Macroman,
    Is it possible to use three different LEDs instead of one RGB LED?
    BTW, we really need some pics and a video!! :D
    Keep up the good work. :)
  7. RaptorLord
    RaptorLord What's a Dremel?
    6 Aug 2002
    Theoretically speaking, with 1024 columns and 768 rows (if they are 3mm) that would give me a nice 3+ meter screen.... now, where to find a converter to convert a VGA signal to some sort of active matrix LED driver...
  8. Cheese
    Cheese Doc
    6 Oct 2001
    Very nice work Dave - time to get my iron out I think :)
    r.
  9. macroman
    macroman The One
    3 Sep 2001
    Thanks
    As stated in the article getting a good vid is damn near impossible with the kit I have. The led just whites out the picture and doesn't appear to do much! :(
    I will keep trying and see what I can come up with. ;)
    Ice-T yes :)
  10. P5ycho
    P5ycho What's a Dremel?
    8 Aug 2002
    How about recording the reflection on an object, a wall or something?
  11. Yammosk
    Yammosk What's a Dremel?
    8 Mar 2002
    if the led's are brite enough a reflection of the hand is really quite easy to get on camera!!!
    Yammosk
  12. Fly
    Fly inter arma silent leges
    31 Aug 2001
    Macro, I really want to do this but due to lack of skills I cant do the curcuit board thingy. What is the easiest way of creating one? and what do I need?
  13. macroman
    macroman The One
    3 Sep 2001
    The PCB making article should be up this week. ( Maplin sell everything you need ;) ).
  14. Fly
    31 Aug 2001
    close to home then...
  15. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    nice job
    any way we can see a video of it in action?
  16. Kinsy
    Kinsy What's a Dremel?
    18 Jan 2002
    nice work dude, however i do want to take it a bit further...
    if i wanted to wire up, say, 8 more tricolour leds to the circuit, would i have to build 9 separate circuits or could i run them all off one?
    also potentially, could i wire them up so at any one time, 3 are green, 3 are red, and 3 are blue, and as they change colour they shift colour along a line of them, like a chaser?
  17. macroman
    macroman The One
    3 Sep 2001
    As it stands the circuit is designed to run one led only. The transistor stage could be redesigned to run more leds.
    As for the chaser idea, the way to do it would be to repeat the IC2/transistor parts for each section and drive them all from the same clock (IC1).
  18. Kinsy
    18 Jan 2002
    nice, but...
    how dyou do that! all i can do is solder! making the hdd light kit of yours was nice and easy thanks to the diagram and a list of components...
    would it be too much to ask if you could possibly draw me up a wiring diagram for 9 leds ala chaser idea with a list of components pleeeese?
    be very much appreciated:lol:
  19. brumster
    brumster What's a Dremel?
    13 Jun 2002
    Will it have instructions on how to make PCBs without using:
    a) laser printer (dont have 1)
    b) UV box (cant afford 1) or
    c) drawing by hand (urgh)
    or... how about some nice person out there actually making me one of the 10 individual LED version PCBs? Of course I'd be more than happy to pay you for your time and materials :D
    And if that was possible (starts to push his luck) could you make me one of those rainblow effect PCBs too? :p
  20. GigglesOfDoom
    GigglesOfDoom What's a Dremel?
    3 Sep 2002
    5V?
    What all would need to be changed for this to run on a 5V power source? Is it even possible with the ICs and transistors? Many of the LED headers in a PC are 5V, which is why I ask.
Tags: Add Tags
