ram 4-5-4-15 or 5-5-5-12
Discussion in 'Hardware' started by mystilexzero, 20 Sep 2006.
  1. mystilexzero
    mystilexzero What's a Dremel?
    9 Aug 2006
  2. Butcher9_9
    Butcher9_9 What's a Dremel?
    15 Sep 2006
    the last 2 seem about the same and the first one is cheaper so it depends on if you want to spend the extra money
    remember that the latence difference is minor and latence never really was that important to the over all preformance of you pc (unless one was like 1 1 1 2 and the other was like 50 50 50 100 and they where the same speed)
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Get the first lot.
    Camouflage looks retarded and the other sets have looser timings anyway. :)
  4. mystilexzero
    9 Aug 2006
    cool i just bought the 4-5-4-15 timings, not sure why the 5-5-5-12 gold ones are more expensive than the platinum ones but owell. thanks for the help guys! also anyone know for sure what voltage these ram modules go by so i can up my volts on my mobo? also does anyone know a program that tells me how many volts im running into my ram because ive looked all through bios and i couldnt find anything, it just said i can up my volts from +.1 to +.5
