Memory Ram 4 i5 P55 Build
Discussion in 'Hardware' started by chrispy61, 15 Sep 2010.
  1. chrispy61
    chrispy61 What's a Dremel?
    29 Jan 2010
  2. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Looking at the board, it should be OK I think - enough spacing around the socket. What CPU cooler are you using?
  3. roosauce
    12 Feb 2010
    These ones are in stock - slightly more expensive, but also tigher timings.
    They are the lower profile XMS3 sticks ...
  4. chrispy61
    29 Jan 2010
    Titan Fenrir for my CPU cooler?
    What makes them classic out of curiosity?
    Im guessing tighter timings are better?
    Thanks for they replys
  5. roosauce
    12 Feb 2010
    The Titan Fenrir is still a great cooler, although it does have some stiff competition these days.
    Tighter timings are better - I was referring to the CAS Latency of the RAM. This is normally shown as 8-8-8-24 or similar - each number representing how long it takes the RAM to do things. There are some complications when comparing these numbers at different frequencies, but let's skip over that ;)
    Basically, for a given RAM speed (e.g. 1600MHz), lower numbers are better. It just means that the RAM is a bit more responsive - although you won't notice much in real life.
    Unless you're watching every single pound, I would go with the low-profile XMS memory I mentioned to be safe. The Fenrir is a cooler that sometimes struggles against the high-heatsink RAM (although your board looks OK, just can't be sure - perhaps someone else has tried this combination directly and will chime in).
  6. chrispy61
    29 Jan 2010
    Ok man thanks, il go for that.
