Memory RAM errors
Discussion in 'Hardware' started by ConstanT1ne32, 22 Jan 2010.
  1. ConstanT1ne32
    ConstanT1ne32 What's a Dremel?
    18 Sep 2009
    Hey guys, I got G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBRL), I bought it on 21st of sep, its been working fine, but lately I was getting some flashes when playing games. So I checked my GPU and it was fine, then I got bluescreen with Memory_management error. I did Ram stability test with PassMark BurninTest and turns out my RAM is showing errors.
    Is there a fix for this or should I ask for exchange if its not to late?
  2. TheHalfWit
    TheHalfWit Call me dino
    25 Aug 2009
    Before you jump to return the ram kit, if your motherboard is new as well try switching the ram to different slots, then if that doesn't work think about returning the ram. However if switching to different slots on your mobo cures the problem then its your motherboards memory management that's bad and it may need to be returned.
  3. ConstanT1ne32
    18 Sep 2009
    Hmm, strange I went to bios and manually set RAM speeds and voltage to what it says on the sticker(1.5v 9-9-9-24) and tests seem to go fine at least it pases the point where i got errors previously.
  4. Lassar
    Lassar Lean Mean Fighting Machine !
    16 Jun 2009
    Wondering if your motherboard was undervolting the RAM?
  5. ConstanT1ne32
    18 Sep 2009
    well when it was on auto vram weas 1.650, default is 1.50
