Cooling RAM Fins in contact with Cooler stack
Discussion in 'Hardware' started by CanItRunSoldat?, 10 Feb 2012.
  1. CanItRunSoldat?
    CanItRunSoldat? New Member
    8 Nov 2010
    Hey guys, just put together a new rig for a friend and realised he had (rather ostentatiously) picked out some RAM with enormous fins coming off the top. When placed in their slot underneath the protruding Megahalem (again with the bigger is better mentality) the metal fins come into contact with the metal coolerstack. Obviously to have the current going from the memory passing into the CPU through this contact would be an instant disaster, however my question is are the fins on RAM typically insulated, and should I be worried about the two components touching?
    Edit: Looks like its ok, as long as the chips aren't touching. Both grounded so no need for current to travel through them. May as well close this I guess:duh:
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Why would the CPU cooler have an electric current going through it?
  3. wbdog206
    wbdog206 not me
    15 Jan 2007
    I would be more worried about the ram cooler not
    letting the cpu cooler seat properly.
  4. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    This, try moving some ramsticks out of the way and check CPU temps before and after.
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    + 1 to moving RAM. And also, the RAM heatsinks do not make up part of the circuitry on the RAM, so have no current passing through them. Even if it was touching the chips directly it wouldn't do anything as they're plastic.
  6. CanItRunSoldat?
    8 Nov 2010
    Did a bit of testing and seems like the RAM isn't having any impact on the cpu cooler. They are just lightly making contact along the tips rather than propping the cooler up. Thanks for the reassurances, I just didn't want to sign off on it and have him come back in a few weeks/months with a useless chip :blush:
