Notebooks Ram "how to" Q
Discussion in 'Hardware' started by Samurai75007, 3 Sep 2006.
  1. Samurai75007
    Samurai75007 What's a Dremel?
    27 Oct 2004
    Well today I orderd an inspiron E1505 with upgraded Intel Core 2 Duo processor (2MB/1.66GHz/667MHz) and 256MB ATI MOBILITY RADEON X1400 HyperMemory. I left the 512 to upgrade when I get it in to 2gig but cant find any "how to". to install it, anyone know where I can find this?
    Thanks for any help
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Well, you screw it open, take out the old one, and put in the new one, and then you close it again. It isn't that hard, just like with a regular PC, only the DIMM's are smaller, and you have less room to work in.
  3. Samurai75007
    27 Oct 2004
    I was thinking it was one on the bottom like that and one under the keybord... but if there both under the back it would be much better.
    thank you
  4. Glider
    Glider /dev/null
    2 Aug 2005
    If you flip it upside down you'll see various hatches screwed in... One of them gives you acces to your RAM
  5. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
  6. Samurai75007
    27 Oct 2004
    Well I got my laptop and it didn’t come with any restore cd's, I installed XP pro rather then leaving WMC 05 on it. After going through reinstalling everything I find that the sound card is not being recognized after several reboots for windows updates. I did talk to dell and there sending me all the cd's that they should have sent including the drivers cd. This will take a week to get to me though. Anyone have any ideas on how to find my sound card and get it to work? Its a dell inspiron E1505, thanks again.
  7. Blackfish23
    Blackfish23 Minimodder
    13 Oct 2004
    Got to www.drivermagic.com and download and run the software, will find all the devices you have and suitable drivers for you, all you have to do is click the link download and install.
  8. Samurai75007
    27 Oct 2004
    Thank's thats got most of them untill the CD gets here next weekend.
