Memory RAM Issue
Discussion in 'Hardware' started by AoE, 10 Nov 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Had 4GB RAM installed, just increased this to 6GB, however its saying my available RAM is only 3.25GB and my windows rating hasnt budged from 7.3 which is where it was had prior to installing the additional 2GB? Is this correct or do I need to do something as I wanted the additional RAM for usage?
  2. LA3195
    LA3195 What's a Dremel?
    29 Apr 2009
    Unfortunately 32 bit Windows will only recognise 3.25Gb of ram. If you want to take full advantage of your 6Gb you will need to install 64 bit Windows.
  3. AoE
    4 Oct 2011
    Yea just googled, it thanks lol, on the road to 64 bit OS then lol. If there is any bonus the new RAM has a heatsink i guess.
  4. GoodBytes
    20 Jan 2007
    Wait, you were using a 32-bit OS, licking down your CPU abilities into 32-bit mode.... What were you thinking? Anyway, at least now it will be fixed.
    Also don't forget, as you'll re-install your OS, that in the BIOS, to set your SATA Controller mode, from IDE (or also called: Compatibility/Legacy) to AHCI to get the full performance of your HDD. You want to use IDE mode on XP and older OS, and AHCI on Vista and upward.
  5. AoE
    4 Oct 2011
    lost me there man, im still a newb so can only understand some of that lol.
  6. raxonb
    raxonb Minimodder
    5 May 2009
    Just remember that you cannot upgrade from 32-bit to 64-bit OS, it has to be a clean install.
  7. AoE
    4 Oct 2011
    meaning it can only be done if I get a new HDD from which I can boot from?
  8. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    No not quite, just means you can’t go the "up-grade" route.
    So you would need to install the OS from scratch and then re-install all you old programs /games etc..
    Although as long as you don’t format the dive all your old files and folders will be kept (although I would back-up any important stuff just in case).
  9. aNuclearPidgeon
    aNuclearPidgeon Minimodder
    3 Mar 2011
    Or just wipe everything from your current HDD and then install
  10. lp rob1
    lp rob1 Modder
    14 Jun 2010
    This would be an excellent time to change to Linux... :D
  11. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    i usually do this every few months anyway. i accumulate a load of crap i dont actually need. i just back up my docs and downloads i actually want and then just get rid of the whole thing. keeps it in tip top speed
  12. rob the bank
    13 Mar 2010
    Sound advice !
    Its amazing how much effort people will put into gaining an extra 1fps, when a clean install could get 10 x the performance boost, for no cost at all :)
  13. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    I cant tell the difference between 60fps and 62fps.. My eyesight just isnt that good
    as long as its smooth play I am fairly happy
