RAM Model Problem
Discussion in 'Hardware' started by Kroganwrex, 30 Sep 2008.
  1. Kroganwrex
    Kroganwrex What's a Dremel?
    31 Aug 2008
    Hi everybody, thank you for reading my thread, lets get started!
    Ok so i had 2 X 2gb elixir M2Y2G64TU8HD5B-AC ram sticks. One of them is bust and I cannot find a replacement on the internet , would a M2Y2G64TU8HD6B-AC model version of one work? Notice it is 6b-ac rather than 5b-ac like on the original.
    Any input appreciated!
    Also my motherboard is an asus p5n32-sli if it makes a diff.
    Im basically asking whether it is possible to use slightly different models of ram simultaneously.
    Or whether it is possible to use a completely different brand of ram in conjunction with my working elixir model.
  2. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    You can use different brands together, though different timings will be modified to the lowest supported timing. They will also function in dual channel mode, however it is best to use the same model or brand per channel, with the best performance coming from matched pairs.
  3. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    matched pairs will always do better, and with how cheep DDR2 is now, I would just invest in some new ram.
  4. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    I second that. Why worry about finding a match when you get get a new 2 Gig kit for $40 US.
  5. Kroganwrex
    31 Aug 2008
    Hmm,Ok, the 2 models i stated have pretty much exactly the same spec, will It really be that dumb to go for itand get the slightly diff model.
  6. Kroganwrex
    31 Aug 2008
    Anyone?
  7. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Are you spending extra money to get the same chip? If you are, then you should go with a new kit, if not, then have at it, you might lose overclocking ability and a slight percentage of speed/latency, but if you're looking to save cash then you have to decide which place your priorities are.
