Memory RAM not at correct speed
Discussion in 'Hardware' started by louist44, 3 Apr 2011.
  1. louist44
    louist44 Minimodder
    19 Jan 2011
    Noticed this since I build the rig around a week or two ago. I have 8GB (2GB x 4 kit) of corsair DDR3 that should be 1600, but it was running at 665. Went into the BIOS today and enabled to profile1 already saved, the BIOS then showed it at 1600 (the speed it should be) but when I used CPU-Z just now it states it is running at 798hz
    RAM is Corsair Memory XMS3 Classic 4GB DDR3 1600 MHz CAS 9-9-9-24, 1.5V
    I5 2500k
    Mobo is Gigabyte GA-P67A UD4 B3
    Any help on how to get it to run at 1600?
  2. Wira
    Wira Spoderman
    27 Jan 2011
    When you look at CPU Z it is actually double that speed as it is running in dual channel mode
    798x2 = 1596 (fail prolly)
  3. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Nothing to do with dual channel; DDR = double data rate.
  4. Oggyb
    Oggyb Mutant
    15 Jun 2010
    I didn't expect that to be so profound. Why can't motherboards just report the expected speed.
  5. louist44
    louist44 Minimodder
    19 Jan 2011
    oh man I feel like an idiot now ... LOL.
    Thank you!
  6. Wira
    Wira Spoderman
    27 Jan 2011
    I stand corrected :)
  7. adam_bagpuss
    24 Apr 2009
    some do some dont completely up to to the mobo manufacturer
  8. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    DDR means the RAM triggers on the rising and falling edge of the clock. The clock frequency stays the same, but the RAM acts like there have been 2 clock ticks for every single tick effectively doubling the clock.
