Overclocking RAM speed issues
Discussion in 'Tech Support' started by TeenGeek, 28 Aug 2012.
  1. TeenGeek
    TeenGeek Worst touch typing ever.
    11 Feb 2011
    Alright, well, yesterday, after running at stock speeds, i decided that i wanted to overclock a little, for the first time :) so, my CPU is at 4.6 gigahertz (mult=46, bclock=100, Voltage=1.350), BUT according to CPU-Z my RAM is hitting a solid 1066??? it is 2133 Gskill, and when i was running the CPU at stock speeds, with the XMP profile in the bios set to profile 1, i was hitting the advertised 2133??? any idea what the issue is?
  2. TeenGeek
    11 Feb 2011
    Oh, and i tried to manually set the RAM speed/ voltage/ timings, but it was not stable? (i just used the advertised settings off newegg) and in the bios, the RAM registers at 2133???
  3. jamesriley94
    jamesriley94 What's a Dremel?
    22 Jul 2012
    DDR stands for double data rate - ie - 1066 doubled = 2133mhz...
    That means its running fine
    TeenGeek likes this.
  4. TeenGeek
    11 Feb 2011
    Oh, okay, thanks! :duh: į just thought cpuz would post the effective (is that the right word) timings
