Ram Voltages
Discussion in 'Hardware' started by death_star, 1 May 2004.
  1. death_star
    death_star What's a Dremel?
    14 Jul 2003
    I have heard before in my many hours of browsing the [h] overclocking section that its pretty easy to take 2100 up to 3200. I wanna do this to get my system to its full potential with my new Thermaltake Silenttower heatsink :rock: Now to do this what would I have to do. I know I have to increase my ram voltage, (I do have heatspreaders and blower fan on my ram now) but what to 2.7, 2.8? My timings are 8-3-3 I think and what sould I put them as to get the full ability of my ram. Also how will I know if ive put the voltage or timings too high? Thanks.
  2. Tim S
    Tim S OG
    8 Nov 2001
    you need to keep your timings (particularly the latter 3 digits of 2.0-2-2-6) as tight as possible. CAS doesn't make as much difference as many people make it out to do, tRP tRCD and tRAS are the most important memory timings.
    2.8v is usually well within warranty limits for most memory modules, check the individual memory manufacturers specs for confirmation of this... you can get away with +/- 5% so technically 2.9v is fine for day to day use, while still keeping a warranty. :)
  3. death_star
    14 Jul 2003
    Set voltage to 2.8 and set my timings to 7-2-2, booted and beeps, had to reset cmos. Whats this about?
  4. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    It means that your RAM can't handle the tighter timings. Try 6-2-3 or 7-2-3. Or more volts (if your balls/motherboard allow for it).
  5. Tim S
    Tim S OG
    8 Nov 2001
    you more than likely won't be able to lower the timings to 7-2-2-2.0, try getting 7-2-3-2.0 or as close as possible...
    what memory do you have? If you can tell me the memory, I might be able to tell you the IC's and what they're capable of.
  6. Spiral Architect
    Spiral Architect Cooked on Phonics
    4 Sep 2003
    I got my KHX PC3500 running at 2-2-2-11 at 2.9v. It isn't BH5 either.
  7. unclean
    unclean SMP obsessive
    30 Dec 2003
    my PC-world PC2700 is running at 2-2-2-6 @ 2.9v :D
    what does the 6 want to be at? im still confused by that number...
  8. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    The sum of the other 3 numbers I believe... However Nforce users find that using 11 is faster......
  9. death_star
    14 Jul 2003
    My rams just some kingston 2100 I beleive. Runs stock at 200 mzh.
