Motors Random adventures of a spanner! (Pic heavy!)
Discussion in 'General' started by grungedead, 3 Aug 2008.
  1. grungedead
    grungedead Minimodder
    8 Dec 2005
    Model: X Reg 1981 Mk1 Polo
    Engine:
    42k 1598cc 1.6 16V (Lupo GTI - 123bhp)
    5-Speed Box
    Suspension:
    Fully Adjustable Front Wishbones
    Rose jointed Camber adjusting top mounts
    Strengthened strut tops
    Lupo Gti Front Shocks and Springs
    Mk1 Polo Steering Arms
    Lupo Stub Axles
    Mk1 Polo Rear Suspension
    Shell Modifications:
    Bulkhead removed
    Seam welded
    Seat Runners Removed
    Modified Gearbox Mount for Lupo Gearbox
    Brakes: Lupo GTI 256mm Brakes
    Wheels and Tyres: OZ Routes 14x7
    Comments: Will be receiving delivery of this project in the next week, got some seat mountings to weld in, get the shell prepped for painting and then get some bike carbs and inlet manifold made up along with some aftermarket engine management to deal with it all.
    Will update this thread with more details when i get my hands on the old girl
    couple of updates,
    I've managed to pick up an M-Tech Automotive Megasquirt V3 Ecu brand new for 175 quid, This comes with the following:
    Megasquit V3 Ecu (With new case)
    Wiring loom
    Data cable
    Software
    The ECU is built to this Spec:
    V3 ECU
    4x COP Ignition drivers
    GM Sensors
    VR Crank Pickup
    This is ideal for a Throttle bodies transplant for 8 Valve or 16 Valve non Turbo.
    It can run any 4 Cylinder by wasted spark/ or any 4 cylinder COP engine such as GTi6 if it uses a trigger wheel (either 36-1 for 60-2) so pretty much any VW, Ford, Vauxhall, Pug, Citroen etc etc
    I know the lupo has a 60-2 wheel so thats all good, will just need to go lop off all the connectors from a crash damaged loop or polo gti.
    also managed to get some schroth harnesses with pre-tensioners for 82 squiddlers that shall be finding there way into the car, would take pics but cant be arsed. they are similar in colour for the first blue which makes me sex wee everytime.
    and my potential colour choices
    Woop, the polo is here, a friend kindly lent me a space in his workshop for a few months. what a legend
    anyway some piccies
    The polo tucked away in la garage
    the engine, and loom with plugs for the various sensors
    The bell housing is leaking, i think the rubber seal needs replacing but ill drain the gearbox oil and investigate
    decat downpipe
    throttle body has already been replaced from a fly by wire to a cable version
    Adapted lupo driveshafts
    lucas 54 calipers for 256mm brakes
    cable shifter loosly in place, holes have been drilled
    but this needs removing to allow it to lie flat, it shall meet mr angle grinder
    various pictures of the wishbone conversion, thought id just take a fair few for any one thats interested
    not quite what this is? rear gearbox mount maybe? or possibly,
    and some of the various bits of seam welding
    some bits rob was selling which i think ill be stickin in the car
    Sifted through all the other parts to find out what wasnt needed and theres a fair bit
    will eventually picture it all gand get it up for sale to clear teh sapce.
    got loads of jobs to do, big and small, cant even be arsed to start listing them all now, and they say a picture tells a thousand words, well ive just wrote an essay with this laptop crashing post :lol:
  2. ufk
    ufk Licenced Fool
    3 Jan 2004
    That looks like its going to be a lot of fun,someones put a lot of work into the shell, you should put a log up on the Club Polo forums, they appreciate nutters with big plans for polos.
  3. grungedead
    8 Dec 2005
    hahaha im a regular on there, mad about polos and golfs:) been on here for years though and still mess about with my pcs so like to keep people updated with what im up to
  4. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    That's going to be completely sick. Keeping it looking sleeper-ish to torment Corsas and Saxos?
  5. grungedead
    8 Dec 2005
    Got a few things done today,
    Cut out the notchy bit on the transmission tunnel, so i can make a shifter template to make a base to attach it all up, nearly went deaf using the angle grinder in the car, ear muffs needed!
    Got the Hocks off and popped the OZs on, temporarily as i want to put the hocks on my mk1 golf shell which ive sold, and put the black lorbers with near new 195/45/15 eagle f1s on the loop while i find some 14 inch tyres or sell the routes.
    Also got a good gander at the hub setup, noticed there was an awful lot of play in the bearings inside the hub, it may be due to the fact theres no driveshaft in there, but im going to check the mk1 golf hubs tomorrow to check for thier movement inside the carrier. The mk1 Golf hubs will fit the lupo driveshafts, lupo struts and the wishbone ball joint. It will also allow me the hub carrier spacing to fit VWII Calipers, and a brand new vag mk1 polo master cylinder. Although i will only have 239mm brakes for the time being it means i can get the car running and mot'd and then find out if there is enough room to fit the mk1 golf servo and linkage with the engine installed.
    If not i will have to invest in a remote servo before i can run the 256mm brakes as the larger pistoned calipers means the pedal would hit the floor long before your brakes had any real bit without the use of a servo
    The balljoints look at a skewif angle which is in part due to it being jacked up at the time and i think with the engine installed more weight will be applied on them which will allow to sit true. hopefully :)
    also while having a wee smoke i made a list of some things to do but theres loads ive probably missed out.
    Stuff to do
    Stuff to get
    * Exhaust System
    * Seats
    * 14 inch Tyres
    Stuff to do
    Braking & Suspension
    * Fit New Master Cylinder
    * Fit Golf Mk1 Hubs
    * Fit VWII Calipers & 239mm venteds
    * Fit Braided Hoses
    * Make new solid brake lines from mc to regulator and front caliper hoses
    Body
    * Rust treatment on a few areas
    * Primer/Silver Paint
    * Waxoyl
    * Seat Runners
    Engine
    * Replace Bell Housing & Gasket
    * Change Gearbox & Engine Oil
    * Get a crane and fit
    Shifter & Pedal Box
    * Make Template for Shifter Base
    * Mount
    Fuelling
    * Fit Fuel Pump & Accumulator
    * Fit Fuel Lines
    Megasquirt
    * Read, read and read
    * Set Initial ECU settings for specified settings
    * Assemble Loom
    Other Jobs
    * Pedal Box Modifications - Cable Throttle, Push Pin Servo, Hydraulic Clutch (i think? :p)
    * Relocate Battery to Boot
    * Fit Harnesses & Pre-Tensioner Relays
    * Fit Battery & Fuel Cut off Switches
    * Uprated Headlight Loom
    * Fit Ancillary Wiring Loom
    Further Jobs
    * Replace Bearings in Lupo Hubs
    * Make Neccessary adaptations to Mk1 Golf Servo Assembly
    to allow use of lupo calipers and rear disc conversion
  6. grungedead
    8 Dec 2005
    will torment them no matter mate, but yep it stay moderately understated on the outside, not sure what overall feel in going for inside, nothing flashy by any accounts, cable tied clocks on non dashed Cheesecake, not sure whether to get a mk1 polo dash flocked or experiment with a lupo or mk5 polo dash.
    after seeing a ppc magazin about building your own cars wiring loom i was tempted just to have a bank of switches for various things like lights, engine fan and other odds n sods, then just get various guages, a tacho and speedo.
  7. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    looking good, keep the thread updated so we can see how your doing :D my first car was a polo many years ago so i def wana see how this turns out! good luck!
  8. grungedead
    8 Dec 2005
    Had a bit of a chiller day at the unit, Rob was changing the hub over on his cabby for one from my red shell, which solved his humming niose thats plagued him for the last week or two.
    I stuck the lorbers on the polo and while the wheels were off sprayed the arches with metal ready.
    Plan for this week is to prep the interior, wire brushing it all and then getting some metal ready on it and lashing it all with por 15.
    then nnce thats done i can get the inner arches and engine bay sprayed up, Robs trying to tempt me to spray the whole car there while we have the whole car stripped so i reckon i could be tempted now to save fannying about later.
    Zee polo also met its younger sister too :)
  9. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    christ do you have access to a full garage?
  10. grungedead
    8 Dec 2005
    pretty much haha :) it was going to be a driveway project like the others but my mate is an absolute legend and is sorting me out space and man hours too while he waits for his mk1 to come back, i said i would help him rebuild it as he cant remember how they go back together and im forever taking them apart
  11. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    The wheelbearings need to be compressed by the castle nut on the CV joint in order to work properly. Without the proper tension there will be play in them.
  12. grungedead
    8 Dec 2005
    sound man, thats what my polo bible uncle steve said, another mate told me that with the engine in and no driveshafts in the bearings can crush, however at 675kilos kerb weight, without an engine and fully stripped the car weighs as much as a feather so shouldnt have any problems like that
    ta for in the info
  13. Xen0phobiak
    8 Aug 2002
    NP.
    They can crush, but if you're only pushing it about by hand you should be OK. What I'd do though is take the shafts out of the outer CV's, Ducktape some plastic over the open ends of the CV's then fit them to the hubs and torque them up. Safe then :).
  14. grungedead
    8 Dec 2005
    Me and walsh started on the floor today, got a fair bit done, also s iifted thru a few more of the spare parts
    couple of pics after a hoover
  15. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
    *sniff* I miss my polo...
    ontopic: I remember how light they are, one of my mates would lift the arse end and turn it so i'd have to mess about getting out was funny the first couple of times...
  16. Krikkit
    21 Jan 2003
    Another awesome polo log, great stuff. I'd love to get myself a project car someday and just sort it out, learn some mechanical skills. Keep it up! :D
  17. grungedead
    8 Dec 2005
    hahaha yeh people used to do the same to my old mini, what polo did you have?
    you should deffo give it a crack mate, well worth it!
    somre more done on the floor pan and transmission tunnel, made a bit of a start on the firewall
    wire brushed the seam welds to get rif of some of the surface rust
  18. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    The engine is too far forward.
  19. grungedead
    8 Dec 2005
    nice observation skills, whats the problem?
  20. Clocked
    11 May 2004
    Twas a C reg 1.3 i had (think i may have linked to it before), wasn't in too bad condition if i say so myself... When I got her she still had the original tape deck in her, whilst I was waiting on my new head unit coming I had only one tape and that was from the same yeah the car was made... The Top Gun Soundtrack!! was awesome listening to that and bombing around the back roads!!
