Notebooks Random critical shutdowns
Discussion in 'Tech Support' started by ModSquid, 6 Sep 2026.
  1. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Another day, another stupid problem with no apparent explanation in my world of computing.
    The laptop - which I am currently using as a desktop ie. plugged in all the time and mostly powered up all the time, due to the desktop being out of action and time to fix it being in increasing scarcity - has recently started playing silly bggrs with me.
    Shuts down of its own accord, a quick check in Computer Management at the Windows Event Viewer indicates "critical battery trigger met", yet when I turn it back on, the battery is at 51%.
    I get that I'm probably knackering the thing (it refuses to charge to 100%...ever) but that's for a different day. Needs must, at the moment.
    But this fake battery shutdown - wtaf?!
  2. Midlight
    Midlight Modder
    6 Jun 2011
    Can you remove the battery? Could be on its way out and causing issues.
  3. ModSquid
    16 Apr 2011
    Not easily. It's a Dell XPS 7390 - I looked up taking it apart a while back to sort the SSD and potentially repaste it and it seems a nightmare. Not just screws but clips that are apparently made of angel hair and Murano glass.
    Loath to do it at the moment as it's my only working machine. I have run a battery report though and it didn't look terrible.
  4. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    I used to have a phone (heck I've still got it) that had a battery indicator all over the place. It would often shut down if doing something intensive and the indicator was below about 40%. Other times it would run down normally to maybe 3% - 7% and shut down. Restarting it would show anywhere between 20% and 50% (but then it would run down relatively quickly).
    Is there any settings you can tweak in Power & Battery that might change the behaviour? I'm thinking Battery Saver or profiles when plugged in or on battery?
  5. ModSquid
    16 Apr 2011
    Yeah, I've changed everything on "plugged in" to be "don't shut down" and critical battery to be very low. It must be something either hardware-related that's triggering the Windows shutdown incorrectly, or a Windows setting that's activating when it shouldn't...??
