Peripherals Random Mouse Tracking
Discussion in 'Tech Support' started by vdbswong, 26 Apr 2009.
  1. vdbswong
    vdbswong It's a Hedgehod
    23 Apr 2009
    Hi,
    It's currently being used with my HTPC system and is part of a Microsoft mouse/keyboard wireless combo.
    Basically when used on the coffee table the mouse fails to respond or shows sign that it's not tracking properly. It appears to be a signal problem of some sort since it's evident whether or not a mouse mat is used and the mouse functions perfectly at other locations (will elaborate in next paragraph).
    The issue does not appear to be related in terms of height or distance from the receiver nor physical interferance (i.e. blockage of signal) since the mouse tracks perfectly on the sofa (further away than the coffee table) or closer to the coffee table. In fact the only place it doesn't seem to track is being physically *on* the coffee table...
    Don't suppose anyone has any ideas ? ¬.¬
    Thanks for any help :p
  2. martinblueprint
    martinblueprint New Member
    14 Mar 2009
    I would have thought a coffee table is quite a smooth surface with no texture on which to track.
    Have you tried a variety of surfaces?
    Have you also tried...and I know ti soudns silly...changing the batteries?
  3. vdbswong
    23 Apr 2009
    I don't think it's the coffee table's fault since it doesn't track whether or not i put a mousemat there or not... sometimes it'll track perfectly but it'll usually be a short one off and quickly go back to skipping/not responding.
    TBH i actually haven't tried changing the batteries simply because it tracks perfectly on the sofa or on my lap which seems to imply that it's not a power issue =X.
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    Try the batteries anyway, though I had this problem with a wired mouse, and what fixed it was replacing it.. Call the company, maybe they can replace/repair it?
