News Raspberry Pi Camera Module now available
Discussion in 'Article Discussion' started by Gareth Halfacree, 14 May 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Am I the only one thinking low cost homebrew GoPro?
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Attach camera to Pi, install OpenCV, add LED illuminator ring, raise massive middle-finger to Vicon.
    As soon as they get 720p60 and/or 640x480 120fps capture working, that is. 30fps is good for proof-of-concept, but that's going to give you a headache if you try and track at that rate. Hopefully the latency of capture is low enough for real-time work (though it doesn't look like you can feed raw unencoded sensor data via the video stream).
  4. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I want to use one as an IP security camera. Just chug it in a tupperware box and use some bathroom sealant along the edges.
  5. Guinevere
    Guinevere Mega Mom
    8 May 2010
    A GoPro is £200. By the time you've bought a PI, the camera, a battery,wifi adaptor and a charger you don't have really that much left to hand fabricate a waterproof housing with a mounting kit and accessible controls.
    More flexible? Maybe.
    Cheaper? Not by much.
    That's why GoPro became THE standard for extreme cams. Because they are so cheap!
  6. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Its a shame there is no Power over Ethernet version of the Pi.
  7. edzieba
    14 Jan 2009
    While it's not 'proper' negotiated 802.3af PoE, quite a few people have bodged power supplies onto the unused ethernet pairs to power their pi's, e.g..
  8. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    Well considering the Pi, Cam, Battery+Charger / Power & Wifi can all be picked up for around £100 so plenty left for a small custom housing.
    So, more flexible? Definitely.
    Cheaper? Clearly by a large margin at almost half the price.
  9. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    As cool as it sounds, I don't think there'd be much of a comparison. The GoPro would be a hell of a lot lighter, smaller, resilient and I bet the image quality would be better.
    Plus a second hand hero 2 is about £150.
  10. Andy Mc
    Andy Mc Modder
    23 May 2002
    Those PoE splitters are really good, I use one for powering and connecting my Draytek 120 to my Netgear UTM10. Saves me so much hassle what with the phone socket being in a stupid place.
    Why bother when you can get a Horyzon HD? I intend to use one when I eventually get the funds together for a tricopter build.
  11. Sheiken
    Sheiken Wat?
    9 Jan 2005
    And here I was thinking I'd come up with something worthwhile! eh!
