SketchUp Raspberry Pi Case
Discussion in 'Modding' started by Jake123456, 23 Jan 2012.
  1. legoman
    legoman breaker of things
    28 Feb 2010
    Im waiting for the Gert board to come out. This does require more power obviously but does also mean more options and toys. plus a slightly bigger box
  2. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    Linky link please Lego? :D
  3. j0rd
    j0rd FLOSS folder
    13 May 2011
    IIRC the R-Pi guys really dont recommend overclocking these SoC's since, something to the effect of "it wont last long" the ARM SoC their using isnt much designed for it. also the RAM is done PoP and on top of the SoC so that will absorb any heat before a HSF does. IIRC the OC issue isnt heat removal but component degradation
  4. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Jake just google it and loads pops up. They are expansion boards with various things on. I can't find the page right now as it is silly o'clock and I am tired. I will take a look in the morning if I remember, I don't know if there are any planned development timescales though as yet.
  5. emmmm
    emmmm What's a Dremel?
    29 Jan 2012
    Was reading the suggestions about plexiglass and the early one about a wooden box and thought : "Steampunk"
    Maybe a wooden box with a stained glass top - the logo in the stained glass could be a raspberry ?
  6. dancingbear84
    16 Oct 2010
    I know it is a bit later than morning...
    Gert board
    Sorry if my post sounded arsey, it wasn't meant to. I had just been rudely awoken at 2.45am by little people. and had to stay up till I knew I would be woken up again, if that makes sense.
  7. Jake123456
    25 Jan 2011
    Its no problem Dancing Bear ^.^ I didn't find it rude at all, thanks for the link though : )
    I have been thinking about the coloured plexiglass on top though, I'll keep you all updated ;) (Y)
  8. jamesn
    jamesn What's a Dremel?
    15 Jan 2012
    i cant wait for these to come out, really exciting and will be keeping an eye out for cases.
    i think i want an underwater case...
