A/V Raspberry Pi HDMI to Dell 23" via Display Port
Discussion in 'Hardware' started by dynamis_dk, 17 May 2013.
  1. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I'm looking to play at setting up my raspberry pi for xbmc duties so I'm looking at options for hooking up to my Dell LCD so I can sit at my desk and play.
    Do we have any confirmed working adapters to allow me to take the HDMI from the Pi to a Display port on the Dell screen?
    The dell has DVI, VGA and Display port but the DVI and VGA are both in use and I don't really want a switching box so would like to use the displayport :)
    advice please :clap:
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    I don't think its possible to go from hdmi to displayport in that way, at least not with a simple passive adapter.
  3. dynamis_dk
    23 Nov 2005
    That's kind of what I'm looking to find for sure. There is plenty of adapters on eBay but I'm not buying till I know it will work and since its just for testing anything over £10-15 is out of the question
  4. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Can you swap one of the existing confections over to display port?
    I spent ages looking for an adapter for mine and then realised I could just hook the PC up via display port instead of DVI.
  5. dynamis_dk
    23 Nov 2005
    Hmmm maybe, pretty sure my gfx doesn't have displayport out but I I can easily convert DVI to displayport then yeah that would work :)
  6. qualalol
    qualalol What's a Dremel?
    24 Aug 2011
    You can buy HDMI to DP cables, but they depend on a Displayport output that can recognise the cable to send an HDMI compatible signal on the cable, the other way round doesn't work (I tried) -- you'd need an active converter for that to work. Similarly DVI to DisplayPort needs an active converter.
    If you can then try and switch any other device over, and then use a HDMI to DVI cable / adapter for the RPi (HDMI and DVI are essentially the same thing electrically but with different connectors / audio), but otherwise you'd need an active converter.
