Other Raspberry Pi motor control?
Discussion in 'Tech Support' started by woody_294, 28 May 2013.
  1. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    I'm planning a Raspberry Pi robot project and was wondering if there was anyone on here that does robots?
    What's the easiest way to control motors with the Pi? Probably 3-6v and 2A. I'm getting an Arduino Uno for some servo stuff later on but at the moment I want to build a simple 2 wheeled bot. I'm not averse to making circuits either I just don't know where to start.
  2. woody_294
    31 Dec 2008
    Pretty please? I found a sweet tamiya gearbox and I will cry if I can't make it work!
    Sent from my LT18i using Tapatalk 2
  3. theshadow2001
    3 May 2012
    Probably what you already know, but you could use a mosfet a transistor or solid state relay. The pi would switch the device of choice and that in turn would switch power to the motor. I believe but am not certain that there are I/O boards that interface to the gpio pins and they might be able to switch the necessary power without further interfacing needed
  4. woody_294
    31 Dec 2008
    That works for me, there are straight up switched voltages off the gpio? Just need to find a German maplins now if that's the case.
  5. theshadow2001
    3 May 2012
    The gpio switch a low voltage. 3.3 volts I believe. So 0 volts when off 3.3 when on. The power they supply is also very low only a few milliamps which is shared among all the outputs. So one output on its own could supply more power than if all of them were turned on. Hence why you need the interfacing technology. Be that a third party board or something you whip up with a few transistors
  6. woody_294
    31 Dec 2008
    Thanks shadow, saw the boards like picoborg and such but delivery would take a while to here and couldn't find anything in Germany. Guess I'll do some project board transistors and see if I can make them work. Not sure about reverse though.
  7. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I'd look on the RasPi / Arduino boards as I've been looking into programming attiny85 chips for a little project using the Uno and although not my point of interest, I've seen loads of robot stuff online this last couple days using Pi/Uno
  8. woody_294
    31 Dec 2008
    Will do dynamis, raspi board is not working on tapatalk but will check the arduino ones!
  9. theshadow2001
    3 May 2012
    There you go that took all of 30 seconds of googling
    http://www.robotroom.com/BipolarHBridge.html
    If you can work out your requirements to get one transistor interface working (and make the motor turn in one direction) you should be able to work out what you need to get the above circuit up and running.
  10. woody_294
    31 Dec 2008
    Thanks again shadow, I don't usually have this much trouble working things out!
  11. qualalol
    qualalol What's a Dremel?
    24 Aug 2011
    You might also want to look at the Gertboard: it's actually more expensive than a Pi, but offers loads of I/O, including some motor specific stuff:
    http://www.element14.com/community/docs/DOC-51726/l/assembled-gertboard-for-raspberry-pi
    It can be connected directly to the top of an RPi and comes with a manaul full of examples (I've got one but not used it yet, but there's plenty of stuff on the Internet using it). It does however need an additional power supply for the motors (up to 18V).
    Might not be quite what you're looking for though as it does offer way more than you'll need, but you could always look at the schematics and just replicated the parts you need.
  12. woody_294
    31 Dec 2008
    Will look into that for the future if I find I need more stuff but I'm trying this out on a budget at the moment, lol. Hopefully will be ordering my pi tomorrow, I'm just smacking my head against the wall at the moment trying out ubuntu on my laptop, I can't even get the touch screen right or install a single driver!! Lol
