Hardware Raspberry Pi: the modder's dream machine?
Discussion in 'Article Discussion' started by brumgrunt, 26 Jan 2012.
  1. hodgy100
    hodgy100 What's a Dremel?
    2 Jun 2008
    pretty stoked to use one of these as a media pc :)
  2. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    need more RAM.... LoL
    I can see this in my car, as the Zotac mitx is a bit large !
    dunx
  3. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    Already working on designs for a fullcover waterblock for it ;)
  4. wyx087
    15 Aug 2007
    when can i buy it?
  5. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    What about a dozen of these networked together to render?
  6. vampalan
    vampalan What's a Dremel?
    18 Jun 2003
    Someone forgets about the shifting demand for programmers in the UK, that the main programming industry has now been outsourced to massive programming warehouses aboard where it is much cheaper to find a contract there for something there or to even setup a subsidiary/joint venture.
    Yes, there is a niche market for niche programmers, just like this web site, but even this website had to change with times.
  7. Gareth Halfacree
    4 Dec 2007
    There's already a name for a cluster of Raspberry Pis: a Bramble Patch. Yarly.
  8. DbD
    DbD Minimodder
    13 Dec 2007
    It's just a 700mhz ARM11, same as for example you got in a zune or a lot of old phones. i.e. in nvidia terms it's basically a tegra 1. We are now onto quad core A9's (tegra 3).
    Shame they didn't do a faster version - not just for performance benefits but the old cpu doesn't support many of the features of newer chips for which most software is now designed making it harder to port that software to a rasberri (e.g. flash).
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    It's a matter of cost.
    The RasPi is intended to be for developing hacking (in the original sense) skills, not just for grunt work.
  10. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    Ahhh, the problem I found there is no screws near the CPU, and like I said in one of the topics, you could try and bend it across, or possibly, make new holes in the motherboard..
  11. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I don't get it.
    It's just an ARM dev board.
    And even if it does run linux, well, it runs... linux.
    If you want to get people coding, give them something they can write for in, say, Visual Studio.
  12. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Linux has lot's of nice devel tools. I'm a computer engineer and code for a living for 10 years now, I used to use Visual but sincerely I really prefear coding with emacs.
    It is a perfect and cheap way to learn the very basics and this is a treasure for people like me who are interested in embedded computing (drone's, etc.). It is easy to have a soft running smoothly on our crunching machine ... but how many developper can make a good program with restricted CPU and memory ? This board is the way to learn great programming skills.
  13. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Are you saying a fully operational computer with all the relevent inputs and outputs that can be bought for $35 (or less) isn't interesting? I'm half tempted to buy one just to use it as an uber-geeky dandly-dice in my car.
  14. wyx087
    15 Aug 2007
  15. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    The Pi is one of the options I am considering for controlling my cooling loop (by the end of the year I expect to have a complex wc loop cooling multiple computers, possibly using underground pipes to cool the water). I have been considering a mini-itx system to double as a dedicated firewall, but the pi would be an excellent and nicely compact way of doing it :) If I take that route, it would be housed in the bottom section of the Little Devil case I'll be building a system in throughout this year :)
  16. Gareth Halfacree
    4 Dec 2007
    I liked the sound of that, so I tried to order it from Mouser (TI's UK distributor). £4 for the device. £12 for the postage. :wallbash:
  17. Risky
    Risky Modder
    10 Sep 2001
    I'm using a T-balancer for this at the moment but would be interested if a project to use this as a WC monitor/control device gets some momentum.
  18. Jake123456
    25 Jan 2011
    I read somewhere, can't remember where that this is a lot more powerful than the new iPhone 4S, not sure if thats correct or not..
  19. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Pair this with a USB powered touch monitor and you have an extremely power efficient jukebox. Ahh, the possibilities are endless!
  20. wyx087
    15 Aug 2007
    uk.farnell.com/texas-instruments/msp-exp430g2/kit-dev-msp430-launchpad/dp/1853793
    Farnel never fails :)
    Jake, what it is saying is that its graphics processing is twice faster than iPhone 4S, which has one of the fastest SoC in terms of graphics. RPi's CPU unfortunately will be very weak, not comparable to those modern SoC's out there.
Tags: Add Tags
