Cooling Rate my watercooling system to buy
Discussion in 'Hardware' started by Finsta, 22 Sep 2004.
  1. Finsta
    Finsta What's a Dremel?
    22 Jul 2004
    Anyways, here it is.
    A TDX Copper
    5 1/4 bay
    12V D4 Pump
    6800 DD Block
    BIX 120mm with 1 sunon
    10 feet tygon
    What will be cooled:
    P4 2.8GHZ C and hopefully a 6800GT.
  2. Simonsnet
    Simonsnet What's a Dremel?
    25 Jun 2004
    Sounds good. Personally I would go with one of the TDX kits from coolercases as it'll give you a better rad. If you email paul he'll happily swap the DD res for a 5 1/4 bay res as you say you want. (I did this too). You would probably have to get the gpu block separately but I'd advise emailing paul with the list of what you want and see what he suggests. I've found him extremely helpful and their prices damn competitive.
    Let us know how it goes.
  3. Finsta
    22 Jul 2004
    Feel free to suggest different parts. I am always taking in suggestions.
  4. daniel_owen_uk
    daniel_owen_uk What's a Dremel?
    1 Sep 2003
    Any idea where you will be getting the DD 6800 block, I can't find stock of them :(
  5. Finsta
    22 Jul 2004
    Direct. :D
    People, I'd like to hear more opinions on what to get. So please, post your opinions.
  6. thorilan
    thorilan What's a Dremel?
    25 Aug 2003
    on a scale of 1 to 10 i give it a 4
    keep in mind 5 is average so 4-6 is in the average range
    the reason being is that the bay res is kind of tacky. and not needed.
    if you are set on a res make sure you are getting a res for the right reasons.
    next is the rad. its not a bad rad but for price vs performance you can do better.
    then there is the pump. personaly i think you could get 2 of them and run them in series and do much better or switch it out for something else
    if you give us more of an idea about which goals you have these numbers could change .
    performance? looks? quiet? cost? overclock? budget you have etc etc.
    all important in making your decision
  7. Firehed
    15 Feb 2004
    But who wants to spend $150 on pumps? The DD ones are quite powerful to begin with anyways, I wouldn't worry.
    I totally agree on the radiator though. The BIX may look cleaner than a normal heatercore but they're just too expensive!
    I also agree on the bayres - I hate how they look. But then again I don't like the look of any dangerden reservoirs. The criticool waterplant looks nice but it's no Aquatube (but that's not meant for big-bore tubing anyways, not to mention how expensive it is)
  8. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    I'd suggest a heatercore for better performance. May not look as good, but it sure performs well. Plus, there a little cheaper.
  9. Risky
    Risky Modder
    10 Sep 2001
    It looks like a fairly mainstream 1/2" system.
    The main weakness I seen is that Sunnons aren't the best fans in terms of airflow to noise ratios. (Try Papst, Panaflo, SilentX, Noiseblocker...)
    A bay res isn't my favourite, but the res is never a critical component so its really a matter of aestetics.
  10. Blood
    Blood What's a Dremel?
    4 Jan 2004
    In my experience, papst are fantastic :)
    go with them !
  11. epidemik
    epidemik What's a Dremel?
    11 Sep 2004
    its ok :rock:
  12. Mister_Tad
    27 Dec 2002
    as said above, papst or panaflo for the fans, im a big "fan" (HAHA! umm) of quietness in a system
    the pump can be noisy at the best of times too, an eheim 1250 is completely silent with great flow rates as well
    all depends on your idea of quiet mind you, there are plenty of people who are quite happy ot have tornadoes and deltas in the PC, im certainly not one of them
    can you fit a 2x120mm rad in the case? that would make the airflow through the rad a bit less important than with a single, so you can get away with quieter fans (thermochill rads are almost identical to the BIX ones except they have a bleed valve, if you think you will need that sort of thing)
    btw, the NV68 is an amazing block :rock:
