Rather n00b-sounding question
Discussion in 'Hardware' started by McGarnacle, 29 Jun 2002.
  1. McGarnacle
    McGarnacle What's a Dremel?
    7 Mar 2002
    Hey guys, I just umm, acquired an old AMD K-6 system from work, and the chip is a K-6 550, but the mobo and case are AT format. I wanted to make a lan box out of it so I went online looking around for a new Socket 7 ATX mobo to use with it, but I keep finding Socket 7 and Super Socket 7.
    Here's my question, whats the diff between these two? And which one should I buy?
    Cheers all
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I should think that super socket 7 and socket 7 are basically the same. And the k6-550 will work in a super socket 7 mobo. I am running a k6-400 in a gigabyte ga-5ax for a linux server.
  3. Alaric
    Alaric code assassin
    3 Nov 2001
    this would prolly be better in Hardware.... hold onto your hats! :D
    btw i think u need a super socket 7...
  4. herbs
    herbs Nobody but us chickens
    7 May 2001
    If I remember correctly Socket 7 was an intel thing for a pentuim upto 233 mhz(266 if u listen to some ppl) then intel went to slot 1 for the p2, but amd/cyrix etc carried on using the socket 7 but ali/sis etc had to create new chipsets to run higher than 233mhz these are known as super socket 7 mobos. They all accept 75-233mhz chips but super socket 7 go upto 500mhz + (can't remember excatly).
    I think any board you would buy nowdyas are super socket 7.
  5. rK@NE
    rK@NE Rover's gonna get it...
    20 Dec 2001
    Yeah thats how I understand it too, I think with Super Socket 7 you can go to 550MHz whereas with the older boards 233 was the limit.
  6. McGarnacle
    7 Mar 2002
    Hmm, so the Super7's are just second generation socket 7 mobos.
    Kewl, thanks for the help everyone!
    Cheers all
