As above, I've been using UFRaw for a little while now, and it's been fine, however it's started giving me corrupted memory profile errors all over the place, and it's made it unusable. So I was wondering what other people were using?
used to use elements 7 then elements 10, then Adobe dropped the price of lightroom with version 4 and now i'm a very very happy lightroom 4 user.
I'm looking at Lightroom at the moment, just downloading the trial and going to have a go with it, it's not like I need it to do a lot at the moment, since I don't really know what I'm doing yet. Just want something that works
First attempt with lightroom, I like it Original: Edited: You better not come any closer... by George.Yoda, on Flickr
Anything by Adobe. I've used ACR for years and simply can't get enough of it - the adjustments are so incredibly easy and well laid out.
Lightroom is brilliant - simple but powerful. The presets are great too, and you can get more from presetpond.com
Yeah I'm having more of a play today, and it seems like a pretty awesome bit of kit, not looked at the presets yet.
Software which came with my 550D? Didn't even realise it came with anything, I'll have a looksie this afternoon
I got the canon stuff with mine. Its actually very good. But yeah, lightroom is great also so either should be fine
been using lightroom for over a year. I defintely recommend it. Especially if someone is debating between lightroom or photoshop. As for the canon tools. The software your looking for is called DPP or Digital Photo Professional. It should be on the disc that came with your camera. And while your at it you might as well also load the EOS Utility.
