Case Mod - Complete Raz3r D3sk - Finished! - Final video online
Discussion in 'Project Logs' started by l3p, 21 Sep 2013.
  1. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    At least I rock the red blue dress and fishnet stockings well :hehe:
    G0UDG likes this.
  2. l3p
    l3p www.^.nl
    1 Nov 2010
    At the moment very busy at work, still hoping to finish it this summer :)
    So .. 'small' update again.
    First a replacement for the slot bracket.
    And found a way to still use the HDD brackets :)
    A nice bed for the SSD's.
    Also bought some more acrylic fittings from another modder.
    Measured, drilled and filed all holes for the 'bridge'.
    Also the connections for the HDD's.
    Built in the fan controllers and connected them to the 14 fans.
    Used 3M Dinoc to hide the red Sata slots.
    And started with the loop from the benchtable. Added a small reservoir on top.
    So .. a little further.
    Here's something I've been walking around with for a long time.
    A logo for the legs and top panel.
    Then you have an idea but .. how to continue?
    Glad there were 2 awesome guys I got to know from a previous project who wanted to help me out.
    <3 Parvum systems CNC :)
    Thanks a lot Justin and specially Shaun for making my figment reality! (Sorry mate :D )
  3. siliconfanatic
    10 Sep 2012
    That. Looks. AWESOME!
    Coming together even better than I thought it would!
  4. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Epic new stuff Peter!
    I wonder who wants to see it coming together more, me or you xD
  5. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    it looks so good!
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys!
    If you only knew Hukkel ....
    Some things just need to be done first :)
  7. imersa
    imersa Parvum Princess
    9 Apr 2009
    We made it in the end! Two thumbs up :D
  8. hanssx2
    hanssx2 Minimodder
    1 May 2014
    wohaaa great work guys. Awesome as always
  9. l3p
    l3p www.^.nl
    1 Nov 2010
    Had to spend a few hours on the hot attic :)
    The acrylic borders are now completely enlightened. (see video at the end)
    Also started with the loop on the left side.
    The back will still be quite some work.
    But this loop will probably remain like this.
    I love chaos :)
    Still can't wait to fill it up.
    Video of the RGB controller with UV leds.
  10. Hukkel
    20 Dec 2012
    That is smexy, apart from the disco part in the end.
  11. l3p
    l3p www.^.nl
    1 Nov 2010
    Never going to use the disco part, maybe just to entertain my daughter, she likes it :rock:
  12. l3p
    l3p www.^.nl
    1 Nov 2010
    And further on the loop :)
    Also I need a paper next to it for the flowdirection.
    3 hours and 1mm of skin later.
    Here the funpackage I got from Razer almost a year ago :)
    Off course had to unpack it.
    Back to the loop!
    Another long waited package arrived.
    Because I didn't count on it anymore I had to change plans.
    So slept a night on it.
    Think the contrast is better like this..
    And ... the pumpstation.
    With this I can make one big loop for both pc's with 4 rads and 4 pumps.
    Or one loop per system with each 2 pumps and 2 rads.
    Backside finished too.
    Also added 2 green LED strips on the bottom to be able to see something there.
    I will be able to switch it off or dim it with the Lamptron controller.
    Ready to fill :)
    I prefer filling with clear liquid and adding color later.
    Because .....
    I had several leaks, this while I tested everything in front.
    Few hours later 1 radiator seemed to leak.
    Temporary solved it this way.
    But then finally .... loop up and running!
    Mau approves :)
    Next update soon!
  13. Hukkel
    20 Dec 2012
    Great job Peter!
  14. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Wow... such an epic build and the convoluted mass of rigid tubing looks awesome!
  15. imersa
    9 Apr 2009
    Very nice mate. Hope to see this in person. Maybe Dreamhack winter? ;)
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys! You're always invited here imersa ;)
  17. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    THE MARTIANS HAVE INVADED!!! :D
    who needs to go to disco clubs when you have a L3p D3sk :p
    makes me green with envy :)
    so much awesomeness
  18. l3p
    l3p www.^.nl
    1 Nov 2010
    Here some photos now that it's filled up.
    Some with just UV, some with UV + blue.
    Glad I had fanguards there :)
  19. l3p
    l3p www.^.nl
    1 Nov 2010
    And here the final photos :)
    Together with Infantry Productions we will create a final video to end this chapter.
    It has been a project with blood, sweat, leaks, 79 acrylic pipes and tears ... but it was totally worth it :)
  20. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Wow! Not much else can be said... Congrats L3p, you raise the bar ever higher.. dare I ask, whats next?
    J.
