News Razer announces dual-sensor gaming mice
Discussion in 'Article Discussion' started by arcticstoat, 9 Jun 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    Perfectly happy with a laser mouse, but I can see this potentially having an advantage on the range of surfaces it works on?
  3. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    I need this to improve my productivity at work.
    I'll go and try to convince our office manager now.
    TSB
  4. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    I have been meaning to upgrade from my Lachesis at some point. Looks like it might be to a Mamba.
  5. blackcell1
    blackcell1 What's a Dremel?
    20 Mar 2008
    why would you need any more then 5600dpi on a mouse?
  6. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    Its all e-penis. I'm happy at 4000dpi. I might be tempted by the new Mamba. I will see if I still like my X8 when it comes around. I do like the magnetic charge cable and I hope Razer can come up with something similar.
  7. Xir
    Xir Modder
    26 Apr 2006
    Even my simple microsoft wheel mouse optical, surely not a high-tech-gaming mouse has a tracking height of about 1-2mm MAX.
    So yeah, when I lift the mouse to replace it, the cursor sticks...that's the effect they aim for, right?
  8. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I'm on a DeathAdder right now, but I was interested in a Mamba for some wireless DeathAdder goodness. I'll hold and wait for this then; might as well.
  9. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Every mouse I've owned lets me do this. The cheapo $10 logitech mouse I use does this.
  10. DwarfKiller
    DwarfKiller What's a Dremel?
    25 Nov 2010
    The mouse I use now cuts off at about1-2mm already.
    I'll admit my old mouse used to still track well over 2cm though, both of them being laser mice.
  11. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    My G5 still pwns hard
  12. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    if it has 2 seperate sensors, what happens if you rotate the mouse?
    I do that a lot in games where I'll turn it 30 degrees for as better grip or aim at something. I suspect it might cause the mouse to either track wrong or spazz out if not dealt with properly.
  13. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    Assuming they can get the build quality of the Mamba up to scratch. Mine had a squeaky wheel (sorted with ACF-50,) loose shell and the battery door blew off after the battery expanded, lifting the mouse off the desk.
    Replaced it with an Imperator.
  14. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Yup, all just gadget pr0n now. I have no reason to switch my Diamondback 3G until it dies an honorable death. Yet they're gonna claim the extra sensitivity will improve your fps by 10% and kill ratio by 15%.
  15. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I can't even use 2000dpi, :D
    Thinking about it, is it better to turn the mouse up to full dpi and then turn down windows setting?
    Or t'other way round?
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    huh okay I can see how this can help so when will they come out with a dual laser version then lol but really I will have to try this out first hand before I consider upgrading my G9. :)
  17. wafflesomd
    22 Oct 2005
  18. faceplant
    faceplant What's a Dremel?
    25 Mar 2011
    erm doesn't the roccat kone already do this?
  19. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    guys, the reason your cheapo mice dont register any movement when you lift it from the surface is likely due to its inherent imprecision. none of us can lift a mouse a perfect 90 degrees from the pad. a high precision mouse will generally pick up the slight twitching of your twist as you lift the mouse, causing the curser to move while doing so. i know my death adder does.
  20. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    I agree... I too have the Death Adder (mine is the Black Edition). As far as FPS gaming goes, the 3500 dpi that it is set at is good enough.
Tags: Add Tags
