News Razer announces Game Booster beta
Discussion in 'Article Discussion' started by Gareth Halfacree, 21 Sep 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    I sure hope it doesn't disable processing cores! Think you mean processes there ;)
  3. Gareth Halfacree
    4 Dec 2007
    Hah! Yes, yes I do. Fixed, ta!
  4. theshadow2001
    3 May 2012
    I'm highly sceptical of any software that claims to boost the performance of your pc.
  5. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    Same, hows about BT gives it and some similar "game fps boosting" software a run down to see if its worthwhile? I cant imagine it making much of a difference tbh
  6. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    The logic of it makes sense, if you watch the video. However if your machine isn't being taxed on the resources it free up already, then you'll see no difference. I'm in the beta for this and I can definitely see the benefit of it for people. Not for myself, but then I still want to contribute to the beta.
  7. SpAceman
    SpAceman What's a Dremel?
    1 Nov 2010
    I used to have Game Booster installed. It definitely freed up lots of memory. Not sure I saw any benefit though. The best part was when it classified Steam as one of those "non-critical processes" and stopped it running until you set it as one of the things to ignore.
  8. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I'm sure older systems would see some benefit from it but a modern gaming box shouldn't need it.
  9. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Yeah it's more for awfully weak systems. It makes skyrim playable as opposed to a slideshow on my gfs laptop which has 2GB ram a 2.6Ghz dual core and some awful 4 series integrated intel graphics.
  10. suragh
    suragh Derp
    26 Nov 2011
    Downloaded it and tried to use the FPS overlay but it didn't work - 100% garbage
  11. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    I vote bloat.
    I have a 395 byte batch script that kills any random unnecessary processes.
    Any self respecting geek should have disabled unnecessary services and startup guff anyway.
  12. Bede
    Bede Minimodder
    30 Sep 2007
    I used to have an Acer Travelmate laptop, awful thing with 256MB RAM, 1.5GHz processor, IGP. To get a few more FPS in most games I went into task manager and force-killed many of the running processes including explorer.exe - this actually worked quite well, so I imagine IOBit's software does too.
  13. CowBlazed
    CowBlazed What's a Dremel?
    9 Dec 2005
    So if it disables all non critical processes, does it disable itself before launching the game as well?
  14. ajfsound
    ajfsound Minimodder
    16 Aug 2010
    Lol - yes I actually did.
  15. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    For people still running ancient Vista systems with old dual core tech
  16. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    It probably works. AMD had an app of a similar nature floating about the web a few years back. In full boost mode it crippled various bits of Windows. The result on my old PC was a 20-30% effective boost in CPU power, but at the cost of zero security features. I just disconnected from the internet and made sure to switch the app off and restart the PC before going online again. Not something I'd want to use nowadays though.
  17. Ninja_182
    Ninja_182 Enginerd!
    2 Apr 2002
    Bring back game specific boot disks!
  18. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    It has been a while since I had to make one of those.
    Although that is sort of what I do with DosBox.
    Sent on my CM10 JB powered i9100 by TapaTalk 2
  19. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Razer....
    .....no thanks
