News Razer announces refreshed Naga Chroma MMO mouse
Discussion in 'Article Discussion' started by Gareth Halfacree, 9 Nov 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. thom804
    thom804 Minimodder
    22 Oct 2009
  3. SAimNE
    SAimNE What's a Dremel?
    23 Oct 2012
    if they made the main buttons stop that double click flaw i will upgrade to this. my original naga lasted a good 3 years without a single problem, but recently it's been having that annoying double click crap so i've been thinking of an upgrade
  4. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    If a G600 doesn't have enough buttons you must need a spreadsheet to remember all your macros!
  6. russ555
    russ555 What's a Dremel?
    24 Apr 2009
    I'll second this.
    I made the swap after my Naga started having the infamous double left click issue that has been around (and not fixed) since the first Naga's were made.
    The G600 is without doubt better in every possible way.
  7. thom804
    thom804 Minimodder
    22 Oct 2009
    12 Thumb buttons, /w G-shift gives you 24 buttons, /w 3 quick switch profiles gives 72 buttons.
    Still not enough?
