Previews Razer Blade Stealth 13 (2019) Hands-On Preview
Discussion in 'Article Discussion' started by bit-tech, 4 Dec 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    Interesting! I assume it still has eGPU capability via Thunderbolt 3?
  3. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Why are connectors along the sides considered preferable?
    I would much prefer power and Thunderbolt to be on the back. That way I can have a much cleaner workspace as the cables for power and the Thunderbolt hub (which has everything else connected to it) run straight out the back of the machine and I don't have to contend with wires sticking out at ninety degree angles.
    In fact, besides 3.5mm, a card reader and maybe a USB-A for thumb drivers I see no point of connectors on the side at all, they just get in the way. Still a nice looking laptop though, as Razers tend to be.
  4. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I suspect because it allows the laptop dimensions to be significantly shrunk.
    If they were at the back the hinging for the screen would have to be above the ports - Which would add the depth of the hinges to the height of the laptop.
    If it was a luggable/desktop replacement "laptop" Then I'd agree with you. Might as well have ports on the back.
Tags: Add Tags
