Razer Lycosa Issues
Discussion in 'Tech Support' started by GavX, 24 Jun 2008.
  1. GavX
    GavX What's a Dremel?
    5 Apr 2008
    Afternoon all.
    I am having a bit of thrhouble with my Lycosa, ever since I installed Vista 64 the media touch panel never works. I havev installed up to 2.03 and tried every combination of Plug and Play but whenever I seem to let MS install drivers the keyboard stops working. Even the basic drivers from the disk do not let it work. I Am out of ideas and have tried every driver combo. I have just let MS auto install drivers and now the keyboard does not work at all... ideas?
  2. Yotta
    Yotta Minimodder
    10 Mar 2008
    I don't have a solution to your problem, but I can confirm Lycosa does work on Vista 64. I'm using the Razer driver v2.03 for the extras, but it worked fine without.
  3. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    For either of you, do the random keys stop working from time to time? Solved by unplug then re-plug the usb cable, but annoying nonetheless.
