News Razer reveals the Deathstalker Ultimate
Discussion in 'Article Discussion' started by Gareth Halfacree, 16 Aug 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. mi1ez
    mi1ez Modder
    11 Jun 2009
    At that price I would expect proper keys rather than chicklet things!
  3. Guest-23315
    Guest-23315 Guest
    If it had proper mechanicals, and ended up around £200 including taxes, I could see it selling quite well actually.
  4. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    Is the LCD multi touch? it may be useful for navigating windows 8 on a desktop if it is....?
  5. Shirty
    18 Apr 1982
    For some reason some folks actually like typing on laptop scissor switches. I would rather eat my own toes personally.
  6. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    nope. multi touch would put this thing at 400 im sure :-/
  7. Gareth Halfacree
    4 Dec 2007
    Yes - it says so in t'article, y'know. :p
    Actually, it is multi-touch with full gesture support - see above. :p :p
  8. Griffter
    1 Jun 2012
    i do apologise for my ******** bigC... thanks Gareth
  9. dety0505
    dety0505 What's a Dremel?
    16 Aug 2012
  10. Risky
    Risky Modder
    10 Sep 2001
    My G19 is clearly for the scrapheap :(
  11. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I still think the keyboard on my old hp laptop is the best keyboard I have ever used. Having said that, I have never tried a mechanical one yet, so I'm not sure how it compares :)
  12. Shirty
    18 Apr 1982
    Of course it's personal preference, but my giant sausage fingers like to press something down tangibly when I type, I type at about 15wpm on a laptop keyboard :p
    N17 dizzi likes this.
  13. fdbh96
    29 May 2011
    I type about 15wpm on any keyboard :D
  14. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    CLACK CLACK CLACK CLACK CLACK
  15. 2bdetermine
    2bdetermine What's a Dremel?
    2 Apr 2009
    For some reason some folks hate square key cap. Is a chiclet style key, try before making silly comment.
  16. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    I hate complaining about innovation but I'm not entirely sold on the "Switchblade" idea.
    For the macro keys with little displays, it's the same problem I have with backlighting: you have to look away from the monitor to use it, which is never ideal particularly when gaming. If you're really into gaming (as I hope you would be if you're spending this much on a gaming keyboard) you likely can touch type and will be capable of memorizing what each of your macro keys do without a little picture to remind you each time. Additionally, the placement is akward at best. It's incredibly far over for left handed use and right handed use has the obvious downside of having to stop using your mouse. Surely you would want to bind all of the standard letter and number keys before going over the numpad area.
    The touch screen is even more awkward. Good luck with left handed use, that thing screams right hand which means every time you think of using it you have to consider if it's worth letting go of your mouse for. Media control? Mumble/TS control? System information display? Since you have to pause whatever you're doing and move your mouse hand over it's not exactly much better than simply tabbing to the program in question and controlling it with your mouse. Or, for information display, simply buying a cheap second monitor considering the cost of this keyboard.
    The one application where I can see this keyboard really coming into its own is keyboard only games, which are fairly rare. Some games like MMOs can be fairly effectively controlled with just a keyboard and having two hands on the board means easy access to every single key, including the ones on the right which a board like this emphasizes.
  17. Crossing
    Crossing What's a Dremel?
    20 Jun 2011
    Don't they name all their keyboards after spiders? Well, this one is named after a scorpion. Missed it by that much.
    Seriously though, looks cool, but way too gimmicky and expensive. Release the touchscreen as an add on for $70 and call it a day.
  18. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    I look forward to reading some reviews but a mechanical option would be welcomed.
  19. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    Finally a KB that can replace my Logitechs.
    Ordering two of these.
    S*D
  20. longweight
    7 May 2011
    I really like chiclet switches so I like this board :)
