News Razer's Synapse hit by root certificate vulnerability
Discussion in 'Article Discussion' started by bit-tech, 10 Jul 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Vault-Tec
    30 Aug 2015
    Oh goody!
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I miss the days when every piece of hardware didn't come with its own software. :(
  4. el_raberto
    el_raberto What's a Dremel?
    4 Nov 2016
    How about the Razer Synapse 2 software that many of us are still obliged to use, hopefully it is free from this idiocy?
  5. Gareth Halfacree
    4 Dec 2007
    Fire up Edge or Chrome, cliky da linky, and it'll tell you if you've got the shared-secret certificate installed. If you see an error, you're good on that front - but might still have a different root certificate installed. You'd have to look in the certificate store to figure that one out.
  6. el_raberto
    4 Nov 2016
    Yep, I get the error message so ok on that front but when checking the certificate store, there's none listed as "Razer Chroma SDK" but there is a "chromasdk.io" listed?
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    My last 2014 Left hand Naga finally started dying. I'm sad to lose the ergonomics of it but happy to be free of the nasty "Synapse" software. This just adds another reason not to look to Razer for a replacement.
  8. Gareth Halfacree
    4 Dec 2007
    Article updated with comment from Razer, denying that having a root certificate installed is an issue now the private key (still trivially extractable) is generated per-machine.
Tags: Add Tags
