RDP issue
Discussion in 'Tech Support' started by goldstar0011, 28 May 2019.
  1. goldstar0011
    goldstar0011 Well-Known Member
    2 Sep 2007
    So I have my main PC, 2 monitors, main is 1920×1080, the 2nd one runs a nice little 1366×768 and I'm having some issues with RDP usage.
    Issue 1
    My server is tucked away under the stairs so I access it through RDP, when I full screen it on the main monitor, looks and feels as if the I'm using the server all fine but when I move the RPD session to the 2nd monitor and go fulls screen the theme returns to basic and becomes unresponsive but I know the clicks, drags and key preses are being recieved because if I move the RDP to the main screen it returns to normal and whatever I did has worked.
    I think it's something to do with desktop composition setting as that stops the issue but them all screens loose the theme etc
    Issue 2
    The RDP loads to the the main screen, when I move it to the 2nd screen and maximise, it's trying to keep the resolution of the main screen so it's adding scroll bars.
    I do prefer the RDP on the 2nd screen as sometime I'm watching YouTube etc whilst getting the server to do stuff.
    Help is appreciated
  2. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Sounds like the second monitor is getting see as 1080p; is the monitor driver for the off-screen 'playing nice' with the RDP app.?
    Is the RDP app. set to default to the off-screen...?
  3. WarrenJ
    WarrenJ Well-Known Member
    14 Oct 2009
    Can you manually set an RDP screen resolution like you can in teamviewer? This may help with Item 2.
  4. goldstar0011
    2 Sep 2007
    Yes but even it loads on the 2nd screen it's windowed so i have to full screen it manually
  5. Jeff Hine
    8 May 2009
    You sure your 2nd screen is 1366*768, native...?
  6. GeordieStew
    GeordieStew Member
    7 Oct 2011
    Try Remote Desktop Connection Manager (now an MS product). It's good. And you can play with display resolutions.
    goldstar0011 likes this.
