RDRAM Questions
Discussion in 'Hardware' started by Soulfly22583, 5 Jan 2006.
  1. Soulfly22583
    Soulfly22583 What's a Dremel?
    12 Jan 2004
    Okay guys here is the scenario -
    I have a P4 computer that was given to me a while ago. I got it up and running last night and started looking into it a little closer. Upon closer inspection i found out that the chip is a P4 1.6GHz chip with 256MB of RDRAM running (I have 2 dimm slots available). I dont know the make of the board so i cant give you that information.
    My questions are -
    1) Can I take this chip and place it in another motherboard that makes use of DDR memory without any problems?
    2) If the answer to the above question is no then will i be able to add more RDRAM to the system?
    Any and all feedback is welcome!
    Thanks!
  2. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Yes, and yes.
  3. Soulfly22583
    12 Jan 2004
  4. Tibby
    Tibby Back Once Again
    9 Oct 2005
    Soulfly, would you be giving up the Rdram?
    I am in the same boat as you, and 512 would be alot better than 256!
  5. Soulfly22583
    12 Jan 2004
    If that board would work with the chip then i would definately give up the RDRAM.... i priced out a 512 stick of samsung on newegg and it was $212... more than i care to spend on this project.
  6. Tibby
    9 Oct 2005
    wtf?
    Check ebay that price is just crazy.
  7. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    RD ram is that expensive, cheaper to move over to DDR mate :)
    I had a Intel system with RD ram, ages ago in about 2000, had 256mb too, didnt bother upgrading to 512 as as you can see - rd ram prices are ridicoulous. (sp?)
  8. hitman012
    hitman012 Minimodder
    6 May 2005
    RDRAM is proprietary and is only fabbed by Rambus, which is why it's so pricey. I'm not even sure if they make the desktop modules any more; they seem to be concentrating on ultra-high speed systems for consoles and the like.
    Definitely hop onto the DDR bandwagon if you can - RDRAM died a long time ago.
  9. KayinBlack
    2 Jul 2004
    They still make it, and the house server is on it as well, but I don't buy, I scavenge. I scored some 1066 a while back, nice stuff...
  10. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    First off, check and see what socket it is. If its socket 423, youre probably stuck with RD-RAM. If its 478, put that sucker on a DDR based board and put some cheap DDR RAM in it :D
  11. Soulfly22583
    12 Jan 2004
    Well if this is true then its a 423... thats if im reading it correctly...
  12. Tibby
    9 Oct 2005
    Is the sytem you got a dell?
    Mine is.
    Old family PC.
    I am building an AMD rig tho.
    Gonna use this as secondary for when my mate comes over for some gaming.
  13. Soulfly22583
    12 Jan 2004
    Nope not a dell... was a custom build my friends parents got a couple years back- cant give you any more information than that though, sorry bud.
  14. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    The first 478's that Intell made were the 2.0 GHz, if I remember correctly, but what I do know is that the CPU that you have is a Willamette core and is 423, so unless you can find some PC-600 RDRAM, you're screwed.
  15. Soulfly22583
    12 Jan 2004
    I pretty much already accepted that it is a 423... now just to find some cheap RDRAM... ha!
  16. Guest-16
    Guest-16 Guest
    It's not fabbed by Rambus, companies by lisenses off Rambus and then produce it. Unlike DDR which anyone can make free. You could buy Hynix and Samsung RDRAM at the time.
  17. hitman012
    6 May 2005
    Really? I wasn't aware that they licensed it; guess you learn something new every day :).
  18. Strategy
    Strategy Banned
    19 Jul 2005
    Run CPU-Z to find out what socket type and core it is.
