Re; Advice sought
Discussion in 'Tech Support' started by D1662, 20 Jul 2006.
  1. D1662
    D1662 What's a Dremel?
    26 Nov 2005
    :read: Hello :read:
    I have used PC Mighty-Max v9 and printed off the report diagnostic report and there is a total off 930 missing links.
    The PC is getting slower on the start up
    Outlined below is the information about my PC
    Computer:
    Computer Type ACPI Uniprocessor PC
    Operating System Microsoft Windows XP Home Edition
    OS Service Pack Service Pack 2
    Internet Explorer 6.0.2900.2180 (IE 6.0 SP2)
    DirectX 4.09.00.0904 (DirectX 9.0c)
    Computer Name SN030202120580 (Terry Home)
    User Name Terry Macavoy
    SMTP E-mail Address terry@macavoyt5.wanadoo.co.uk
    Logon Domain SN030202120580
    Date / Time 2006-07-20 / 18:53
    Motherboard:
    CPU Type Intel Celeron D 346, 3066 MHz (23 x 133)
    Motherboard Name ECS P4M800-M7 (3 PCI, 1 AGP, 1 CNR, 2 DDR DIMM, Audio, Video, LAN)
    Motherboard Chipset VIA P4M800 Pro
    System Memory 1024 MB
    BIOS Type AMI (10/19/05)
    Communication Port Communications Port (COM1)
    Communication Port ECP Printer Port (LPT1)
    Display:
    Video Adapter NVIDIA GeForce 6600 (256 MB)
    3D Accelerator nVIDIA GeForce 6600 AGP
    Monitor LG L1750G [NoDB] (1603131820)
    Multimedia:
    Audio Adapter Realtek ALC655 @ VIA AC'97 Enhanced Audio Controller
    Storage:
    IDE Controller VIA Bus Master IDE Controller
    SCSI/RAID Controller H+H Virtual CD SCSI Controller SDK
    SCSI/RAID Controller VIA SATA RAID Controller
    Floppy Drive Floppy disk drive
    Disk Drive Maxtor 4R080L0 (80 GB, 5400 RPM, Ultra-ATA/133)
    Disk Drive OEI-USB CompactFlash USB Device
    Disk Drive OEI-USB SM/MS/SD USB Device
    Disk Drive Maxtor 6 V300F0 SCSI Disk Device (279 GB)
    Optical Drive H + H DVD-ROM DVD-41SD SCSI CdRom Device (Virtual CD-ROM)
    Optical Drive HL-DT-ST DVD-ROM GDR8162B (16x/48x DVD-ROM)
    Optical Drive TOSHIBA DVD-ROM SD-R5112 (DVD:4x/2x/12x, CD:16x/10x/40x DVD-RW)
    SMART Hard Disks Status OK
    Partitions:
    C: (NTFS) 74049 MB (53848 MB free)
    D: (NTFS) 286181 MB (228888 MB free)
    Total Size 351.8 GB (276.1 GB free)
    Input:
    Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    Mouse HID-compliant mouse
    Game Controller Microsoft PC-joystick driver
    Network:
    Primary IP Address 81.79.122.245
    Primary MAC Address 00-14-2A-B8-5A-5B
    Network Adapter VIA Rhine II Fast Ethernet Adapter
    Network Adapter WAN (PPP/SLIP) Interface (81.79.122.245)
    Modem PCI Simple Communications Controller
    Peripherals:
    Printer hp deskjet 940c series
    Printer Microsoft Office Document Image Writer
    USB1 Controller NEC uPD720101 USB OpenHCI Controller
    USB1 Controller VIA VT83C572 PCI-USB Controller
    USB2 Controller NEC uPD720101 USB 2.0 Enhanced Host Controller (v1.0)
    USB2 Controller VIA USB 2.0 Enhanced Host Controller
    USB Device Packard Bell Diamond 1200Plus WIA Scanner
    USB Device USB Human Interface Device
    USB Device USB Mass Storage Device
    USB Device USB Printing Support
    DMI:
    DMI BIOS Vendor American Megatrends Inc.
    DMI BIOS Version 080012
    DMI System Manufacturer ECS
    DMI System Product P4M800-M7
    DMI System Version 1.0
    DMI System Serial Number 00000000
    DMI System UUID 00020003-00040005-00060007-00080009
    DMI Motherboard Manufacturer ECS
    DMI Motherboard Product P4M800-M7
    DMI Motherboard Version 1.0
    DMI Motherboard Serial Number 00000000
    DMI Chassis Manufacturer ECS
    DMI Chassis Version 1.0
    DMI Chassis Serial Number 00000000
    DMI Chassis Asset Tag 0123ABC
    DMI Chassis Type Desktop Case
    DMI Total / Free Memory Sockets 2 / 0
    I am considering doing a nondestructive restore, I have Norton Ghost 10 installed, could I use the data that is within that software to reinstall the current configuration, or will that just return the PC to the current problems.
    Regards
  2. DougEdey
    5 Jul 2005
    Ok..........
    You do realise 99% of these types of "services" are scams to make you fork out for software which doesn't actually do anything at all?
    Have you actually been having problems with your PC?
    (By the way, you do not need the RE; in your thread titles)
  3. D1662
    26 Nov 2005
    Sluggish start up
    It the little unexpected things that pop up from time to time, like the new hardware wizard starts up and I have no idea where it came from.
    I have started a thread with regards that item
    I started a Norton Virus check at 08:20 and have stopped it at 18:40. it had not completed the scan off the system by then.
    Regards. :thumb:
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    :eeek:
    I'd suggest a reformat/reinstallation might be in order :idea:
  5. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    sounds like your system is messed up on the software side. probably from you downloading random programs like 'PC Mighty-Max v9'.
    The best thing to do would be to format as this would remove everything. You'll be wanting toi back-up first though.
  6. D1662
    26 Nov 2005
    :duh:
    Your advice is very welcome as the system is starting to crash on me but automatically restarts itself. Is there any other things that I could try first at this current time. I am using Microsoft Home XP with SP 2 ..... could that be the problem.
    Thank You for your time in this matter.
