Case Mod - In Progress RE-Define XL - Update 20th November
Discussion in 'Project Logs' started by Wissel, 15 Aug 2012.
  1. FannBlade
    FannBlade What's a Dremel?
    4 Nov 2012
    Very ingenious layout! That's a lot of hardware you got stuffed in there.
    Great looking build.
  2. Wissel
    Wissel What's a Dremel?
    12 Aug 2012
    Thanks.
    Small Update - Lighting
    I was originally going to make the LED's from scratch and plug them into a Mod Smart board but I decided to just buy the Mod Smart LED's as well.
    The Mod Smart board is a cracking little thing that can take up to 20 LED's and powers from a single molex. It also has a 2 pin switch connector if needed.
    Before instating the lights I did a quick check to make sure they all work
    Then installed them and added a Bitfenix LED strip to the bottom of the case to up-light the board
    Not the greatest pic I know but I'll take some better ones once the sides are fitted.
    Also, the studio/office is taking shape now, here's a couple of pics
    I've also sent the side panels of to Pulse Modding today
    and here is how they should look once they return
    I'll update again once the panels are here.
  3. Telefonskaft
    Telefonskaft What's a Dremel?
    31 May 2011
    Damn that looks really good!
