Case Mod - In Progress Reactor Meltdown |20-07-2014|Illumitube crowdfunding only 1 week left!
Discussion in 'Project Logs' started by skyrip, 26 Sep 2013.
which fitting type would you take (renders at post #43)
Poll closed 4 Feb 2014.
  1. round flange type
    35.7%
  2. hexagon flange type
    0 vote(s)
    0.0%
  3. compression solid tube fitting
    71.4%
Multiple votes are allowed.
  1. skyrip
    skyrip What's a Dremel?
    22 Jun 2013
    small update:
    currently reworking the fittings as i found the finish of to low quality, did test the pressure tightness and they work great, now it is just a matter of perfecting my manufactering method and some small design tweaks
  2. skyrip
    22 Jun 2013
    very small update, have been busy with some cables, i will be using coated copper wires instead of sleeved wires for the 8 pin and 24pin motherboard, both using extenders.
    got blisters on my fingers now but here is the first result of the 24 pin:
    they are 2mm thick laminated copper wires, they soldered onto the connectors remarkably easy.
    also this build is going a bit slow because im working on plans to make a large production batch of the illuminated fittings between 100 and 1000 pieces, currently have parts on the way to make me some second stage prototypes. biggest difference will be the production method and the use of a tiny pcb inside the fitting for 3 0603 leds or 3 leds on their side.
  3. ChromAnomaly
    ChromAnomaly What's a Dremel?
    7 Nov 2013
    Good grief. That's going to look really sharp if you can get all the wires to line up neatly, like tiny little copper tubes.
  4. skyrip
    22 Jun 2013
    it is something that has to be done at the very end, i have tried doing it while working on it but as soon as i bend it a little bit it goes back into chaos :p
    the actual plan was to remove the isolation and tin coat the wires and use the clear plastidip to provide the insulation but tin coating the wires turned out to be very troublesome :wallbash:
    maybe the copper version wil someday be replaced with a silver coloured version :naughty:
  5. ChromAnomaly
    7 Nov 2013
    You can zinc coat copper quite easily, which should give you a nice silvery finish. If you plastic coat it soon after, it should stay nice and shiny I think. Just bring a solution of NaOH (aka sodium hydroxide, lye) and zinc powder to a boil, and dip the copper in for ~1min. Both NaOH and zinc powder are fairly easy to come by.
    Alternately, you could always use aluminum wire. It got a bad rap for starting house fires when used as in-wall wiring, but as long as you don't bend it back and forth too many times it generally works just fine.
  6. r104_for
    r104_for What's a Dremel?
    8 Dec 2013
  7. skyrip
    22 Jun 2013
    i will try this when i have again some spare time. thanks for the tip, i will also try again with the soldering iron since last time i tried to do it with a burner and i think it may have become to hot :duh: because the connectors soldered easilly onto the wires.
  8. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    That 24 pin is going to look sweeeet! :) If you don't mind me asking, where did you get the wires?
  9. skyrip
    22 Jun 2013
    i got the wires here: conrad
  10. skyrip
    22 Jun 2013
    it has been a couple of weeks but i havent stopped working on my solid tube designs, needless to say i have reviewed about 6 concepts and i now have a final design that im going to prototype in about 2-4 weeks.
    i have also finished my previous design to see how the light element will work with the tubes and the water.
    the first parts i got in were the 0603 leds and resistors to create a more profeccional pcb rather than using the leds in the side
    to compare the performance of some different led types i have made a couple of versions using the same pcb. from top to bottom this is:
    sideled(white), white 0603 led, uv 0603 led.
    the next step was to find a material that could reduce the brightspots that you get with the led lights so i got some samples of special led plexiglass:
    the first is a single layer of the white version:
    next we have the white sheet combined with a second layer of yellow plexi:
    the top nut is there to show the size of the hole that would be used in the fitting.
    red version:
    uv red version:
    i tested a lot more colors and i have suitable material for all basic colors: blue, red, green, orange and white.
    since i didnt want to waste the sample material on making old parts i inserted the led ring in the old fitting using the old type inserts, it does not fit perfectly but in general it shows what the effect will be on the tube and water
    no led on:
    with the uv leds inside:
    next up are the white leds:
    all i can say is that in reality it looks much more awesome, the camera really creates bright spots and reduces the effect the light has on the tube and water.
    in the next weeks i will be busy making the final prototypes.
  11. Meelobee
    5 Nov 2003
    wow man, they're getting better and better! :)
  12. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    They look really good. I'd definitely be in for some of them if i was ever using solid tubing.
  13. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Wow they look brilliant! Loving this log so far dude, can't wait to see where it goes :)
  14. skyrip
    22 Jun 2013
    thanks man :D
    the newest design is really compact and because im planning to make more than 10 i can make a special jigg to enable precision 2 sided milling on the nut and threaded part.
    its only 24mm in diameter so it is quite small considering there is a pcb inside :)
  15. Meelobee
    5 Nov 2003
    Well done, especially the downsizing :)
    And more than 10? How about more than 100 at least?! :D
  16. skyrip
    22 Jun 2013
    If the making of the final prototypes goes well i will most likely start a kickstarter or indiegogo campaign so people can kind of pre-order them, that will give me a clear estimation on how many i should make. That is if the prototypes are of sufficient quality and im really strickt on that kind of thing :p
  17. Theophilus_Field
    Theophilus_Field If all else fails... use the surfacing tools
    17 Oct 2013
    Major Kudos right there Skyrip, Those connectors look freakin' amazing :rock:
    That's a fine looking design you have there. What is it rendered in?
  18. skyrip
    22 Jun 2013
    the renders were made using the solidworks photoview 360 render tool, it really sucks at displaying the light effect for some reason so its not really great but at least its better than the rough sketches :p
  19. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    I like that 24 pin. It looks dangerous. Dangerous is good.
  20. skyrip
    22 Jun 2013
    thanks man, that is what i was going for :D
    i would also like to share the other concepts that i have rendered, i will not attempt to make these in the near future since their increased complexity would be a little bit to hard to begin with.
    the first is based on a ER32 nut:
    The second has slots to tighten the fitting with a special tool:
    the second version is the same but this time the color ring also has the slots that run untill the edge of the tube:
    The fouth is inspired on a tire profile:
    The fifth has round holes for a tool to tighten the nut:
    The sixth has the same round holes but much closer to the tube so the holes are half in the nut and half in the color ring:
    These are some concepts that might be interesting if this ever takes off :p
    so dont expect them anytime soon :p
