Memory Really high memory usage?
Discussion in 'Tech Support' started by Weekly_Estimate, 1 Oct 2014.
  1. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    My computer just seems to start slowly going up and not stop until it's all bloody used then my computer starts lagging like god knows what.... any ideas?
    It's a fresh install and has 49 processes running
  2. Gaming_freak_10
    Gaming_freak_10 Active Member
    5 Jun 2010
    I noticed that there's multiple instances of chrome. Is that a normal amount of Chrome?
  3. Shirty
    Shirty Time travelling rogue Super Moderator
    18 Apr 1982
    It's one instance per tab isn't it?
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Try using something like Tab Hibernation, Chrome can be a bit of a memory hog.
  5. Weekly_Estimate
    1 Feb 2010
    Seems rather odd chrome using nearly 8 gigs of memory for 7 tabs though! I've downloaded the plugin Corky lets hope this helps...
  6. TheMadDutchDude
    23 Aug 2013
    Perhaps a memory leak issue somewhere? Chrome is using ~100MB of my RAM on these forums.
  7. Corky42
    30 Oct 2012
    The amount of memory used for each tab depends on the web site, complicated sites, heavily flash based, lots of images, etc, etc.
    If you are interested in a more detailed view of the RAM being used, you could try using Chromes inbuilt taskmanager (Shift-Esc) Or you could take a look at the "chrome://memory-redirect/" page by typing that in the address bar.
  8. Umbra
    Umbra New Member
    18 Nov 2013
    I would d/load Process Hacker it shows more info about what programs/services/processes are running and detailed memory usage, you can also see network activity in real time and any programs that are online and using resources that shouldn't be like malware.
  9. loftie
    loftie Well-Known Member
    14 Feb 2009
    ^+1, I think I actually used process explorer for the BF4/AMD leak but I can't remember how i did it. If it's guaranteed to happen every time you start your PC, do a full shutdown and not a W8 shutdown. At least for me with my memory leak, a W8 shutdown would not give it back.
  10. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    How many add-ons do you have on chrome, people have been having problems with some add-ons or having many and using a lot of memory.
  11. Weekly_Estimate
    1 Feb 2010
    Solved!
    Seems that removing all the addons i had for web dev stuff made it completely stop memory's between 20 and 30% now so running like a dream :)
