Windows Realtek Drivers - full range speaker setting
Discussion in 'Tech Support' started by jimmyjj, 15 Jul 2012.
  1. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Hi,
    Have been playing around with my sound drivers after updating and noticed an option to set speakers to "full range".
    My question is, should I select this option for my Creative T20s - which are 2.0 (no sub woofer).
    Can it send very low frequencies to the speakers which could damage them?
    Thanks,
  2. theshadow2001
    3 May 2012
    I doubt it's going to kill your speakers. Turn it on and see, an extremely brief google seems to show they are full range speakers. Not having it on full range would be for very limiited speakers like laptop speakers for example
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    The speakers will have their own cut-offs inside so they physically cannot play frequencies outside their ranges.
  4. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Full range speakers are speakers that produce their entire spectrum of sound from a single unit and most of the consumer models are of this kind. If you connected your computer to a 2-way bookshelf or 3-way floorstander system you would have to disable that option as those speakers are not full-range speakers.
