News Reason behind Skype outage revealed
Discussion in 'Article Discussion' started by Tim S, 21 Aug 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. slugs
    slugs Minimodder
    4 Dec 2001
    thats the issue with building a system around users and relieing on peer to peer.
    it does seem appauling they don't have some central infrastruture to under pin the network.
  3. naokaji
    naokaji whatever
    8 Dec 2006
    well.. thats the reason how they can provide people with free to dirt cheap calls...
  4. riggs
    riggs ^_^
    22 Jul 2002
    I only use it at work, and not that often. It seemed to be on and off for a couple of days...
  5. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    I use it to talk to my parents in Germany and had to use my mobile for some days which costed a fortune.
    Hope thats not happening any time soon again
  6. mclean007
    mclean007 Officious Bystander
    22 May 2003
    They do - users log in to a the service via Skype's servers, which track users, maintain accounts, connect calls etc. These are relatively low bandwidth requirements compared to the actual audio streams in a call, which are routed directly from peer to peer. If Skype had to route every call through its own servers it would need an astronomical amount of bandwidth, and would also add latency - not something you want on a voice call.
    It seems that what happened was a failure of the central infrastructure due to unexpectedly high demand for login services.
    Why do you say "thats [sic] the issue with building a system around users and relieing [sic] on peer to peer"? A key advantage of peer to peer is that it removes the single point of failure. Some peer to peer networks, like Skype, function in a way that requires a central hub, and it is usually the central hub (as in this case) that causes problems, because the failure of a single peer is not fatal to the operation of the network. Other networks that operate in a mesh configuration, with no single point of failure, are phenomenally robust, much like the internet itself - servers can collapse, data cables are severed by workmen, whole cities can lose power and yet the internet just re-routes and carries on, with only the users whose direct physical link is lost being affected.
    It's a bug in a service caused by unprecedented circumstances. It happens all the time - you can't test every possible combination of events before releasing software to users. Skype offers its service for free, and has fixed the bug. You can't really say fairer than that so I don't think there's any reason to complain about a two day intermittent outage.
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i use skype and i like it, those days were it was out is nothing compared to what happens to telephones, water, energy and other internet messaging applications that fail randomly and sometimes takes a lot of time to bring them up again.
Tags: Add Tags
