Case Mod - In Progress Rebirth ..... Completed... Total cost £132..
Discussion in 'Project Logs' started by bulldogjeff, 5 Jun 2012.
  1. bulldogjeff
    2 Mar 2010
    I have a funny feeling Dylan will want a few LED's thrown in for good measure.
  2. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Light emitting diodes are prob best electronic device ever.
    I remember when they managed to create a blue one, but i wasnt going to pay the £350 each to get one.
    Nice to see your still doing a few mods and builds.
  3. bulldogjeff
    2 Mar 2010
    I remember when the blue stuff started appearing, everything was always 10 quid more expensive.
    As for the build, it's only supposed to be a quick one for/ by Dylan, but knowing me it will turn in to some thing much bigger. It some how always does..lol
  4. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    everything in moderation dear boy, however since this is Mod-Nation .. Excess Required :)
    I can't remember last weekend let alone when they brought out specific colours of LEDS :(
  5. Paslis
    Paslis Minimodder
    13 Jun 2011
    Following this one for sure. :D
  6. bulldogjeff
    2 Mar 2010
    This week end has turned in to a bit of a blur...lol
    :thumb::thumb:
  7. bulldogjeff
    2 Mar 2010
    So I finally managed to drag myself out of the pub and the sun came out for a while so here's a little update.
    First thing I done today was to finish off the 200 mm fan in the top and get rid of all the gaps..
    A pretty easy job, first temp fixed the fan in place and then I used to alu mesh to support the edges and then filled them with a fiber glass based filler, next it was a case of rubbing down and filling over the top to create and nice round hole and a base for painting later on.
    After that I turned my attention to the front door and made some hole, I know more holes.
    The original vents were filled and rubbed down and the some holes cut in to the panel.
    Now even though I've done the hole, I'm not totally sure I like them, I'm going to fit some nice grills in behind them and I'll make a proper judgment then..
    Then I made more holes...woooohooo
    Nice and simple this time, in the bottom of the chassis
    So thats it for now. Thanks for looking :thumb:
  8. Asouter
    Asouter --------
    18 Jan 2012
    Ahhh pub then the drill, Drunk in charge of a drill, hmmm sounds like a recipe for...well y'know but it is looking good..I bet you drink Carling Black Label :D
    Apophis54 likes this.
  9. Teelzebub
    27 Nov 2009
    Nice one Jeff
  10. bulldogjeff
    2 Mar 2010
    Most of the drinking was done on Friday and then had a reasonably quiet night last night and as for my tipple, I was mainly on the Bulmers and Friday I was on everything...lol :duh:
    Cheers Tel.:thumb:
  11. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    about time we got some updates we need Moooooaaaaaaaarrrrrrrrrrrrr! less drink more work please
  12. bulldogjeff
    2 Mar 2010
    WTF is going on. I know my builds always run in to a snag or 2, but not this early on.
    I'm not a mathematician but I'm sure the last time I checked 200 mm was, well 200mm
    Not according to NZXT, no it's 190 feckin mm. WTF is that all about.
    So now I have 2 choices, mess about to reduce the hole or try to salvage the fan that was in there, which as you can see from the pics got covered in filler.
    I suppose there is a 3rd choice and thats to fit some rubber trim round the hole to reduce it slightly.
    I knew I should have stayed in the pub !!:duh::duh::wallbash:
  13. bulldogjeff
    2 Mar 2010
    Have a look at the last post..I need more drink !!!....lol:duh:
  14. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Yup. It's a well known gripe about NZXT's "200mm" fans. The only fans i've seen for a while that are actually 200MM are BitFenix fans, but they're probably a touch too expensive for you.
  15. bulldogjeff
    2 Mar 2010
    The one I used for the template to make the hole was a bit fenix.
    I've had a look at it rubbed it down and given it some undercoat and it's not as badly damaged as I first thought it was.
  16. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    Shame on you NZXT!!!
    The mod looks awesome so far, Jeff!!!
  17. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    How do the 190mm fans look in place? Do they look too small, or do they look like a nice aesthetic choice?
  18. bulldogjeff
    2 Mar 2010
    Thanks a lot and yes...Shame on them indeed..lol
    They just look wrong, there's a 5mm gap all the way round, makes them look like an after thought, not the nice flush look I was going for.
  19. Blarte
    15 Jul 2008
    lol NZXT caught using the old "yes missy I have a monster in my trousers" old chestnut .. only to be found wanting huh .. lol choice
  20. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I say KILL THEM! KILL THEM WITH FIRE! :rock:
    Good luck fixing it, and have a drink on me! :)
