HTPC Rebuild Advice
Discussion in 'Hardware' started by pyro1son, 25 Apr 2011.
  1. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    I think that my current HTPC needs and upgrade and this is what ive got in mind:
    CPU - AMD Sempron 140
    Motherboard - Biostar N68S+ AM2+
    Graphics - Asus GeForce G210
    RAM - Kingston 2GB (2x1GB) DDR2
    HDD - OCZ 32GB Onyx SSD
    About £150
    will also add a large heat-sink and go passive i want it to be as quiet as possible. also ill probably hold off on the SSD for now and add it later on, also all data will be stored on a different machine so just needs to have and OS, most likely XBMC.
    i also plan to build the case for it myself.
    what do you guys think of the hardware and would you recomend anything different, more power for my money, ect...
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    If you're holding off on the SSD why not a Crucial 64GB C300? They often come down to £85 these day and offer faster read performance.
  3. pyro1son
    18 Aug 2010
    the SSD isnt for speed its for being as quiet as possible, and as cheap as possible, thats why that will be later if its quiet enough then ill miss the SSD
