Build Advice Reccomendations for new PC completely lost
Discussion in 'Hardware' started by Auxilliary, 22 May 2011.
  1. Auxilliary
    Auxilliary Crashes into space stations
    27 Jan 2011
    Budget: £780 max
    Main uses of intended build: Gaming and a little video editing
    Parts required: Motherboard, Processor, RAM, HDD, ODD, Graphics Card and Power Supply
    Monitor resolution: 1680 x 1050
    Storage requirements: at least 500Gb and maybe a solid state boot, dunno
    Will you be overclocking: yes
    Any motherboard requirements: SLI or crossfire depending on what graphics card people reccomend i will add a second one at a later date
    Extra information about desired system: I'd like it to last if possible 3-5 years (the PC in my sig has lasted about 3) and i'd like to have an intel processor either an i5 or i7 sandybridge
    Any help would be greatly appreciated
  2. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  3. Auxilliary
    27 Jan 2011
    sounds good and weirdly enough thats the case i was going t ouse anyway as i have that now, would it be worth getting one of the newer Z68 motherboards?
  4. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    I'd agree on the Bit Tech buyer's guide build. Sandybridge should last you a good while.
    Depending on how much video editing or what kind (eg- is it HD?) , you may want to bump up that RAM to 6GB. Also, storage is so cheap now there's not much cost benefit in getting less than 1TB, can pick up an F3 from Scan for £37 now.
  5. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  6. Auxilliary
    27 Jan 2011
    ill just say yes because some is and some isnt
    with graphics cards would you recommend ATI or Nvidia?
  7. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I second this with the addition of replacing the P8P67 m/b with an MSI P67A-GD53 which is cheaper and gives you both SLI and Crossfire (which the P8P67 doesn't). The MSI will be only the bit-tech buyers guide next month, it is in the magazine already.
    Note that there is a case included in that cost and you haven't mentioned that you need one - so the total will be cheaper.
  8. Auxilliary
    27 Jan 2011
    the case thats in the buyers guide the coolermaster if you look in my sig i actually have it already and ill be reusing it
  9. Fingers66
    30 Apr 2010
    Doh, I didn't read your sig, sorry.
    In that "case" (excuse pun), the enthusiast overclocker build is spot on if you swap the P8P67 with the MSI P67A-GD53 (saving around a tenner) and upgrading the GPU to a 560 Ti or 6950 as suggested earlier. It should bring it to around the £650 mark. I'll do a price list from Scan and post back.
  10. Auxilliary
    27 Jan 2011
    aha its ok, and awesome thanks, do you think it would be wotrth getting 8Gb ram instead of 4 and cooler like the dark rock?
  11. Fingers66
    30 Apr 2010
    All prices from Scan (doesn't include any Today Only specials):
    1TB Samsung HD103SJ Spinpoint F3 £40.07
    Samsung SH-S223C/BEBE £14.87
    Intel Core i5 2500K Unlocked, 1155, Sdy Bridge, QuadCore, 3.3GHz, GPU 850Mhz, 95W, Retail +Free Game £161.00
    8GB (2x4GB) Corsair Vengeance DDR3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, XMP, 1.50V £79.34
    Gelid Tranquillo 4 Heatpipe + PWM, Silent 120 Fan £23.03
    600W Coolermaster Silent Pro Gold, Modular, 80 PLUS Gold, 90% Eff', SLI/CrossFire, EPS12V, 135mm Fan £70.00
    MSI P67A-GD53 (B3), Intel P67, S 1155, PCI-E 2.0, DDR3 2133, SATA 6Gb/s, SATA RAID, ATX, SLI/ XFire £108.88
    1GB MSI GTX 560 Ti Twin Frozr II/OC, 40nm, 4200MHz GDDR5, GPU 880MHz, Shader 1760MHz, 384 Cores £184.27
    64GB Crucial RealSSD M4, 2.5" SATA 6Gb/s SSD, MLC-Flash, Read 415MB/s, Write 95MB/s £90.77
    Total = £772.73 excluding delivery (free as forum member with 20 posts).
    If you factor in saving up to 5% through shopping around and special deals (like Today Only), the cost will come down.
  12. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Nice one Fingers66! Seeing as the OP mentioned a second GPU a beefier PSU is definately in order! :thumb:
    Although why a 64GB Crucial? Wouldn't an OCZ 60GB Agility 3 SSD make more sense?
  13. Auxilliary
    27 Jan 2011
    awesome man thanks, think im gonna get that, just got to save up my pay now so hopefully some of it will have come down in price before i manage to get it
    and blogins that isnt a definate but it was a possibility
  14. Fingers66
    30 Apr 2010
    The 700w 80 Plus Bronze rated Cooler Master Silent Pro is only another £10.
    Re: the SSD, the Crucial I listed is an example and tbh, I am not an expert on which is best.
