Modding recieved my psone lcd. power adaptor help please?
Discussion in 'Modding' started by LiL_MJ, 18 Aug 2004.
  1. LiL_MJ
    LiL_MJ What's a Dremel?
    4 Nov 2003
    hi i recieved my lcd today and i noticed that the power adaptor i got with it is totally different to that seen on bit-tech.
    it looks like this
    so erm where do i cut off the wire etc? how would i go about doing this?
    cheers
  2. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    Can you take it apart?
  3. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Where did you get the power adaptor from ?
    I have been waiting for a month now from one I ordered on the net.
    Mailed them to cancel it today and really want to get one so the kids can use it in the car before going back to school.
  4. LiL_MJ
    4 Nov 2003
    i recieved the cigarette power adaptor with my lcd.
    nobody can help?
  5. X-W4rrioR
    X-W4rrioR What's a Dremel?
    14 Oct 2003
    cig adaptors use direct 12 V... so i guess the wire has 2 wires in it
    ground
    12V
    so i think just take apart the adaptor/cut it off and ull see you got 2 wiers
    one of them 12 V one of them gnd
    not sure though
  6. LiL_MJ
    4 Nov 2003
    i know that thanks but where should i cut? as i need part of the adapter for lowering the voltage from 12v to 7.5v.
    edit: i ripped it open as i had nothing to lose andall there was is a wire running from the pcb to the two metal contacts on the side. the pcb says GND so thats going to ground on my molex. There was also a spring which went to the center of the adapter and thats going to supply the 12v.
    will get pix up soon for anybody else who may get the same adapters :)
