Other Recomend me a cheap smartphone.
Discussion in 'General' started by Umbra, 20 Jul 2014.
  1. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    I don't use social media or spend a lot of time texting on the phone which is why I only have a cheap basic mobile but I'm spending more time on my hobby of photography and want to use a Depth of Field app, so I need a smartphone but I know next to nothing about phones :rolleyes:
    I have no preference for brand or operating system I just need a basic pay as you go smartphone, a quick look in the local tesco and the cheapest is a sony or LG around £65, is there anything cheaper that's worth buying or is that about the entry level price?
    Any advice appreciated.
  2. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Might be worth checking what OS your prefered app uses before you make your choice. i.e. if the one you want to use is only available on iOS, its pointless going Windows or Android.
  3. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    Kronos has a Nokia 520 for sale in the marketplace at the moment for £60 here . It's a quick little phone that would suit as a first smartphone as long as you can get a depth of field app on windows phones.
  4. RedFlames
    23 Apr 2009
    Moto G or Lumia 520, both are decent devices... Both are available unlocked for not that much money...
  5. ch424
    ch424 Design Warrior
    26 May 2004
    If you want a really good camera it might be worth spending a bit more for a Lumia 925? You can get them for £160 second hand or just over £200 new
  6. Umbra
    18 Nov 2013
    Yes, that would have helped :duh:
    Quick check and most of the DoF apps are for Android.
  7. wolfticket
    19 Apr 2008
    Probably a Moto G then unless anything similar has been released since I last checked.
    You may be able to get an Android smartphone for less money (like you mention, £65 and up) but the drop off in specs and general experience is pretty severe in my experience. Cheaper but poor value in the long run.
  8. Nexxo
    23 Oct 2001
    You can; there are several.
  9. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    The Moto E e.g. the even cheaper moto G
  10. wolfticket
    19 Apr 2008
    Ah yeah, I forgot about the E. Probably a good choice.
  11. RedFlames
    23 Apr 2009
    Derp... was thinking of the E when I said the G
  12. Umbra
    18 Nov 2013
    Thanks for your help, I have some options to check out now :thumb:
