I am after sorting a twin monitor setup out, both DVi. I'd like above 20' and widescreen, but really cost is important, yet I do fancy excellent quality. What would be ideal looking in the Dell lineup perhaps?
You have: http://www.trustedreviews.com/displays/review/2007/08/28/NEC-MultiSync-LCD2470WNX/p1 http://www.trustedreviews.com/displays/review/2007/11/09/Samsung-SyncMaster-245T/p1 http://www.trustedreviews.com/displays/review/2006/09/13/BenQ-FP241W-24in-Widescreen-Monitor/p1 http://feeds.engadget.com/~r/weblogsinc/engadget/~3/314644803/ http://www.bit-tech.net/hardware/2008/04/15/nec_accusync_lcd24wmcx_24in_widescreen_lcd/1 http://www.trustedreviews.com/displays/news/2008/06/21/Dell-Launches-Second-Gen-27in-LCD-Monitor/p1
I really fancy that Dell, I noticed OCUK only have the older variant, so will have to do some shopping.
Well it is so happened that I just got to know a deal says that Up to $200 Off Select Monitors sale is going on at Dell Home, I guess that can be useful to you, and here is the link for that deal.
i have LG L226WTQ, and it's a cheap wonder. also have a look at LG L227WT, possibly the best 22inch to date.
Thanks for the links guys, I may end up only wanting to spend about £200, also my Samsung 204BW is intermittently cutting out and turning off, and a whine is apparent. Having used a Macbook for a while I have gotten used to it's glossy screen is their any good quality monitors which offer this or would I be better off with a matt finish Dell 20'?
http://www.overclockers.co.uk/showproduct.php?prodid=MO-026-OK Seems to be a very popular choice at the moment, mainly because it is using the same panels as the much more expensive models (I have forgotten the brand of that one, it is OcUK Value on there, but it is a different brand somewhere else. Another shop, Komplett IIRC, was selling that model with the original brand name, but they went out of stock absolutely ages ago there).
I just gave you links of monitors that SHOULD be better or equally as good as your MacBook screen. I mean a perfect or near perfect score... what else can you ask for?
