HTPC Recommend a blu ray drive and hdd for ripping blurays to my microserver
Discussion in 'Hardware' started by jakemorris3000, 14 Sep 2011.
  1. jakemorris3000
    jakemorris3000 What's a Dremel?
    12 Feb 2010
    Hi guys. Just got my HP 36l setup storing my films and music. Can anyone recommend me a bluray drive and quiet hdd to store the rips on. I'm trying to spend as little as poss but don't mind spending more if it's justified.
    Jake
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Just get the cheapest blu-ray rom drive you can. I got a LiteOn as it was the cheapest at the time and I can't fault it.
    As for HDD, what sort of size are you going for?
  3. jakemorris3000
    12 Feb 2010
    Thanks. As for hdd how much space does a hd film take up once ripped?
  4. noizdaemon666
    15 Jun 2010
    Depends if you're going to rip it 1:1 in perfect quality or not. You could probably compress it, without losing too much quality. Probably get it down to 3 or 4GB, maybe less. A perfect copy is probably more around 10-15GB.
  5. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Ya the brand does not matter. I think the cheapest is around $80 on newegg now.
    @noizdaemon666 - what are you using to rip? I was thinking of upgrading my 123DVDCopyGold to the blu-ray version.
  6. jakemorris3000
    12 Feb 2010
    Just been looking at drives an extra £7 upgrades the read speed from 4x to 10x would this be beneficial when ripping?
  7. noizdaemon666
    15 Jun 2010
    @ jakemorris3000 - read speed should help with ripping as it'll be able to read the disc faster. I think this is the case anyway.
    @Fuganater I've used a couple, WinX Blu Ray decrypter (it's free until tomorrow by the looks of it) and some others.
  8. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    My uncompressed rips are 20-30Gb. If your going to compress it 4Gb then just get a DVD.
  9. noizdaemon666
    15 Jun 2010
    I clearly have shorter movies lol Or I haven't realised it's compressing it down, which is probably the case. But I have done them at ~4GB and it looks still really good compared to a DVD.
  10. jakemorris3000
    12 Feb 2010
    Thanks guys! just ordered a samsung from CCL
    Jake
  11. meandmymouth
    meandmymouth Modder
    15 Sep 2009
    Blu-ray rips can be as large as 50GB but the compressed files of 4-5GB are excellent still
  12. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Yep, the easiest way to drop them in size is ditch the dts / lcpm audio and just use the ac3 track. Unless you have a super amazing sound system, nearly no one notices the difference. If you want them really small it is possible to get them down to 1gb or less and still have quality far superior to dvd.
  13. jakemorris3000
    12 Feb 2010
    Thanks, What software does everyone use?
