Other recommend a digital voice recorder
Discussion in 'Hardware' started by silk186, 22 Mar 2016.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I would like to pick up a digital voice recorder for my wife and I to use when meeting with our PhD advisers. It needs to be suitable to place on a table and record a meetings with 2-3 people that will last around 1 hour.
  2. David
    7 Apr 2009
    She can't use her phone with an app installed?
  3. silk186
    silk186 Derp
    1 Dec 2014
    I was thinking about that, it seems that it wold work for dictation but do you think it would work well enough for recording a conversation between two people while sitting on a table?
  4. Big Elf
    23 Apr 2009
    You can get external microphones that plug into the 3.5mm earphone socket. I used to use one with an iPod Touch to record meetings.
  5. silk186
    silk186 Derp
    1 Dec 2014
    oh, I hadn't thought about that, great idea.
    Did it work well for recording group conversations?
  6. Big Elf
    23 Apr 2009
    I only ever used it 3-way maximum, usually 2-way and it worked really well with everything picked up clearly.
    Bear in mind this was 5-6 years ago so I assume, phones/mics/apps have improved since then.
  7. silk186
    silk186 Derp
    1 Dec 2014
    interesting, any recommendations on brands?
  8. Big Elf
    23 Apr 2009
    Not really, I had a small mic I bought from Ebay in 2009 that looked like this
    I'd just experiment with the onboard mic to see what results are like.
