Displays Recommend a Good sub £400 Monitor?
Discussion in 'Hardware' started by kahanejosh, 13 Apr 2010.
  1. kahanejosh
    kahanejosh What's a Dremel?
    25 May 2009
    Hi
    Sorry this is quite a generalised question. I am looking for a new monitor for gaming, photo editing, graphic design. I would like it to be sub £400, shouldn't be too hard (I hope), full HD and anything larger than say 23".
    Any help much appreciated, thanks.
  2. kahanejosh
    25 May 2009
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
  4. kahanejosh
    25 May 2009
    Thanks again Baz, very helpful. :)
    If anyone can recommend any other monitors, great!
  5. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
  6. Baz
    13 Jan 2005
    We review based on actually using the monitor, not by just reading specs off the side of the box. To quote Antony from his review on the NEC
    "Our input lag test revealed no issues either, with the NEC keeping up to the millisecond with our virtually input lag-free Dell 3008WFP-HC control monitor. While we were worried that the quoted 14ms response time would lead to blurry images and ghosting in games, the NEC displayed roughly the same level of lag as the HP(LP245) - it was fine, if not exceptional."
    It's fine for gaming. I'd challenge anyone to spot the difference between a 5ms and 14ms response monitor in real world use anyway
  7. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Is there not a 24" NEC in the same line? I looked at it recently but couldn't really find any reviews of it if I recall correctly.
  8. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Yes but the 23" is the only model of that line that uses IPS instead of TN IIRC.
