Cases Recommend a large PC case
Discussion in 'Hardware' started by onthejazz, 5 Dec 2010.
  1. onthejazz
    onthejazz What's a Dremel?
    17 Feb 2010
    I would like to build a pc with a large RAID array consisting of 12-24 disks. I would also like to be able to fit in a full size graphics card. (No 5.25" bays will be required). Thanks
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    If you really want 24 disks you're probably looking at a rackmount server case. The most you can get out of a desktop tower is 16.
    Assuming you're talking about 3.5" drives?
  3. onthejazz
    17 Feb 2010
    I might stick to 12-13 drives? Do you have any recommendations? What about an external cage with separate power supply?
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    What kind of budget are you working with? Basically you can do this with anything that has 5.25" bays all along the front, you just stick some 3.5" cages in there and you're good to go.
    Or there's the Fractal XL, add a 4x cage to the 5.25" bays and you have room for 14 drives.
  5. onthejazz
    17 Feb 2010
    My budget is fairly flexible, but I would like to do it as cheaply as possible. I presently have a Fractal R2 with 8 drives thats why I was thinking of an external cage.
  6. onthejazz
    17 Feb 2010
    Can you buy the 3.25 cages separately?
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Sure you can. Backplanes, even.
    Of course you can always just take the side panel off and have some drives sitting on the desk/floor.
  8. that_du^de
    that_du^de give your head a wobble
    29 Nov 2010
    thermaltake mozart tx will hold 12 drives and a full size gfx card/cards.however there is a 2nd compartment in the back of the case you could fill with drives as well.
  9. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Oh my god that thing is hideous, without actually offering more storage than an average full tower.
  10. Beezie
    Beezie What's a Dremel?
    1 Oct 2010
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Having to install additional cages does not count as "out of the box"
  12. Earthmonger
    Earthmonger Gnarled Old Tree
    21 Aug 2009
  13. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
  14. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Oh, good old Chieftec, their cases are built like TANKS. While their internal layout might not be the most modern they ooze of quality. I wasn't sure if their older stuff is still available though.
  15. Beezie
    1 Oct 2010
  16. Beezie
    1 Oct 2010
    dubble post due to lag, sorry!
  17. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    lian li PC-343B or you could get a normal tower case and use something like
    http://www.icydock.com/goods.php?id=48
    they fit into the space of 3 5/14 drives bays, so 6 5/14 drive bays would give you 10 hard drives + whatever space inside the case for drives, prolly 6 more.
    you could of course get the lian li and fill it with the icy docks, that would give you 30 hard drive bays
