Cooling Recommend a quiet fan 140mm for my H110i
Discussion in 'Hardware' started by GaryP, 7 Jul 2017.
  1. GaryP
    GaryP RIP Tel
    31 Aug 2009
    One of the bearings is rattling on the fans that come with my H110i
    Can anyone recommend any decent quiet fans, cheaper the better.
  2. Vault-Tec
    30 Aug 2015
    H100i 140mm. You sure?
  3. GaryP
    GaryP RIP Tel
    31 Aug 2009
    110i GT !!! Oops :)
  4. Vault-Tec
    30 Aug 2015
  5. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Thanks mate :)
  6. Vault-Tec
    30 Aug 2015
    No worries. Shame it's not 120mm as I have a few pairs of fans. One of which are the more expensive Cougars. Best SP fans I've ever used, all apart from the NB Eloop.
  7. rollo
    rollo Well-Known Member
    16 May 2008
  8. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    noctua are king but you'll be paying a high price for them
  9. Vault-Tec
    30 Aug 2015
    Not for outright static pressure they are not. Cougar, NB and Vardar are better. This is why Noctua's new fan which uses the tightest tolerances ever in a fan looks like a Vardar. The only problem with the Vardar and why I avoided it was motor noise. Some say they were pretty bad at low RPM and could chirp ETC.
  10. Sentinel-R1
    Sentinel-R1 Morse Monkey
    13 Oct 2010
    if you want quiet with high SP for a rad, you'll not get much better than a Noiseblocker E-Loop.
  11. Vault-Tec
    30 Aug 2015
    'course, but those are north of £36 for a pair.
  12. Sentinel-R1
    13 Oct 2010
    Money well spent, IMO. Never skimp on PSUs & fans....
  13. Vault-Tec
    30 Aug 2015
    Aye, but he only has 50p :D
    Sentinel-R1 likes this.
