Cases Recommend me a case
Discussion in 'Hardware' started by Ph4ZeD, 3 Apr 2011.
  1. Guest-56605
    Guest-56605 Guest
    SB upgrade is the reason for my new case ;) :thumb:
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    What case you getting?
  3. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    not sure, but i get the feeling you have something against me? not sure what i did to piss you off, but GFY
  4. Guest-56605
    Guest-56605 Guest
    I've gone for a Phantom in black, I'll be gutting the internals however ;)
  5. Ph4ZeD
    22 Jul 2009
    Only got something against people who don't read the thread. Start reading the threads before posting and theres no issue.
  6. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    ph4zed why didnt you ask me this question i have a gtx 580 and i have a fractal r3 so i would go for the R3 also i thought you didnt like fugly cases like the Antec 1200 and HAF hmmmmm??? :D:naughty:
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    How do you work your cooling flame696? I have GPU envy looking at the GTX 580 and just curious of the best solution to cool it in a Fractal R3. Advice would be greatly appreciated. :thumb:
  8. flame696
    15 May 2009
    I have 2 x 120mm Akasa Apache fans as intakes in the front, 1 x 120mm Akasa Apache as rear exhaust, 3 x 140mm BitFenix Spectre's 2 top exhaust and 1 side intake. Gpu temps idle at 39-40c
  9. Blogins
    3 Aug 2010
    How does that sound in the Fractal R3? Wouldn't removing the 'ModuVentâ„¢' for the fans increase the noise of the system?
  10. flame696
    15 May 2009
    its really not that bad i run all the fans off a NZXT sentry 2 fan controller and i keep the fans on 50%. Also i have the case on my desk right next to my ear and its still very quiet
  11. Blogins
    3 Aug 2010
    Well it's good to know it's quiet even with all those fans!
    I'm gonna try a minimalist approach with mine. Decided on a single 120mm Akasa Apache on the upper front intake which will draw in cool air and keep the CPU/HDD happy with any luck. My SSD will be in the bottom so won't really require any cooling (I hope!). I'll use a 120mm Be Quiet! USC Silentwings in the bottom to feed my second GTX 460 with cool air and then another intake of the same fan on the side panel for the first GTX 460 of my SLI configuration. Got a really nice filter for the side panel to stop the dust, or at least cat hair! For the exhaust I'm relying on a single 120mm Scythe Gentle Typhoon rated at 1850 RPM. Fingers crossed the temperatures will be kept under control with this configuration.
  12. sonicgroove
    16 Mar 2011
    just because someone has a certain mount to spend, doesn't mean the whole lot has to be spent does it? indeed, i would consider it good advice if something achieved the objective and came in under budget. if you don't like the advice just ignore it, rather than twatty comments.
  13. flame696
    15 May 2009
    Why are you people fighting for? ph4zed can come across as being rude but he isnt he just said to read the thread and if you dont like him dont post on his thread. People are trying to give advice here and dont want to read posts about personal issues
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Ironically someone called flame stopping a flame from happening :p
  15. flame696
    15 May 2009
    lol im a nice sort of flame (if there is such a thing)
  16. Bloody_Pete
    11 Aug 2008
    Like using explosives to put out a oilwell fire...?
  17. flame696
    15 May 2009
    yeh something like that :thumb:
  18. Sketchee
    Sketchee Suddenly, looters! Hundreds of 'em!
    23 Oct 2010
    The raven really is hard to argue against for the price it is now... but the FT02 looks sooo much nicer!!
    Either would be a b*tch to take to a LAN tho :lol:
  19. Dackman
    Dackman What's a Dremel?
    23 Mar 2011
    Haf X every time
  20. Ph4ZeD
    22 Jul 2009
    Small update:
    Case arrived today. Scan working as clockwork as usual. Crysis load temps dropped 30C (yes, from 86C to 56C). This is with stock cooling. Cable management is bad but cooling potential is amazing with this case.
